Re: Assetto Corsa
Postby SirEisenhower » Sun 30. Oct 2016, 09:37
Ok, I test last night the autoscan, put de script and last plugin on xsim and works nice!
Thanks!
SirEisenhower
Re: Assetto Corsa
Postby AndresVl » Sat 19. Nov 2016, 13:13
Hi, I need little advice please.
I am running 2DOF simulator, powered by arduino UNO, everything is working but moves are really intensive.
I tried lowering strengh, adjust other setting in extractor and convertor, but without any noticable change to moves, forward and backward moves looks fine but left and right are really fast and intensive, please can anyone advice me where I can modify this settings?
Thank you :)
AndresVl
Re: Assetto Corsa
Postby tiopepe » Sat 10. Dec 2016, 23:03
I bought Assetto corsa and I have istalled it.
I have updated list of the game in X-sim extractor: now Assetto corsa is available in my list.
When I start the game from extractor (play game button), Assetto corsa start well, but "play game" button is still available (not grey). In fact, input setup values in converter They do not change (always 0 values). I have updated assettocorsa.dll plugin with Oct 02 2016 version.
If I press play game button when assetto corsa is in running, I see a window with error message (C:\Users\Administrator\Documents\Assetto Corsa\launcherdata index is denied), but in this situation, play game button is grey and the converter works fine.
can you help me?
thanks in advance
tiopepe
Re: Assetto Corsa
Postby sirnoname » Sat 10. Dec 2016, 23:19
Try launcher option in parameters.
http://www.x-sim.de/documents/Howto-gam ... cripts.txt
Button must stay grey.
Been thanked: 128 times
Re: Assetto Corsa
Postby tiopepe » Sat 10. Dec 2016, 23:48
good!
I solved.
I edited script file with:
title: Assetto Corsa startup exchange
games: Assetto Corsa
search_executable: AssettoCorsa.exe
game_parameter: steam://rungameid/244210
mustdir1: steam
unicode: no
plugin: AssettoCorsa.dll
Many thanks
tiopepe
Re: Assetto Corsa
Postby manc0ntr0 » Tue 7. Feb 2017, 21:39
In my case Assetto and TM1638 is already running.
mustdir1: steam
unicode: no
And then I replaced .dll in x-sim and put the las sirnoname attached in this thread.
Thanks for the support!
manc0ntr0
Re: Assetto Corsa
Postby Riton » Fri 3. Mar 2017, 00:14
sirnoname wrote:Try launcher option in parameters.
i have this problem, but i need information, where is the launcher option in parameters?
Edit:
Ok, I found, but I can not save it.
Riton
Images: 70
Been thanked: 16 times
Re: Assetto Corsa
Postby MoparMap » Thu 29. Mar 2018, 15:45
So I put my sim rig back together recently to try out some new cars I got and I spent over an hour just trying to get my bass shakers to work again with no luck. The latest version of the game is 1.16 (I think I have 1.16.13 for what it's worth), and I'm having zero luck getting anything shaking again. The wizard scripts weren't helping to find games and the 2016 plugin didn't seem to work either, though I may have other issues going on. I put the new plugin in place and can launch the game from the extractor, but the "play game" button isn't staying grey after the game launches. Have there been any updates since the latest or is there something else I need to do? I'm wondering if it has to do with 64 bit operating system or something as acs.exe appears to be the launcher, but I believe I have an acs_64.exe or something like that in the same folder. Wondering if the config file needs to be watching for acs_64 instead of the plain acs. Anyone else having any luck with the latest Assetto Corsa version? I have done complete reinstalls of X-sim something like 3 or 4 times now with no luck.
MoparMap
Re: Assetto Corsa
Postby mboRacing » Wed 4. Apr 2018, 18:39
Same here. Can't get it workin:
PLAY GAME -> Button becomes gray -> Game beginn to start -> Button get back to blue, not recognising the running Game!
My workaround was different kind's of changes in the wizard script (Assetto Corsa.txt - according to this tread. The AssettoCorsa.dll (02.10.2016) from this tread. Several different sequences of installing, deleting, registry cleaning. NO WAY.
Nothing helped. I have no further ideas what to try....... Is somebody here ho have it running?
Kindly, mboRacing
mboRacing
Re: Assetto Corsa
Postby ricords » Sat 27. Oct 2018, 12:37
Same here, but that helps:
When the game starts, the AssettoCorsa.exe can be seen twice in the taskmanager, so i tried this and it worked.
I also got the last plugin.
game_parameter: launcher:AssettoCorsa.exe scanexe:AssettoCorsa.exe
mustdir1: steam
unicode: no
ricords
Users browsing this forum: No registered users and 21 guests
