Re: Assetto Corsa
Postby pippo23010 » Thu 14. Jan 2016, 23:40
I'm sorry but this plugin does not work well, my position is shaking uncontrollably, the longitudinal vertical and lateral forces have problems.
how can I thank risolver?
photo of the forces when the car is stopped
http://postimg.org/image/hcgjwh6r5/
photo of the forces when the car is in motion
http://postimg.org/image/j2zkxyoa9/
when the car is moving my sim swings and does what he wants ...
pippo23010
Re: Assetto Corsa
Postby vicpopo » Fri 15. Jan 2016, 21:25
Always works great for me !!
Re: Assetto Corsa
Postby sirnoname » Sat 16. Jan 2016, 01:59
I think he did not made a training drive as the training video shows.
Been thanked: 128 times
Re: Assetto Corsa
Postby pippo23010 » Sat 16. Jan 2016, 19:18
hello sirnoname sorry but I'm Italian and I do not understand what I've written ...
However my problem is that the three forces described above have high values, I saw that the forces reaching 1,000,000 ... I do not think is the right thing.
thanks for your patience.
pippo23010
Re: Assetto Corsa
Postby sirnoname » Sat 16. Jan 2016, 19:28
yes, the values have different sizes from game to game from car to car. There is a tutorial Training Video. You can also enable the automatic learning mode the balanced auto maximum.
Re: Assetto Corsa
Postby pippo23010 » Sat 16. Jan 2016, 20:32
oki thanks.
where I find the tutorial and enable the automatic learning mode the balanced auto maximum?
pippo23010
Re: Assetto Corsa
Postby sirnoname » Sat 16. Jan 2016, 20:45
No tutorial needed, the math setup ask you automatically if you deactivate the auto mode in the math setup after you did what in the Training Video Tutorial is shown. In the math setup there is on the left side some buttons and checkboxes for this options.
Re: Assetto Corsa
Postby pippo23010 » Sat 16. Jan 2016, 21:00
oki thank you
I hope to solve
pippo23010
Re: Assetto Corsa
Postby vicpopo » Sat 16. Jan 2016, 21:58
pippo23010 wrote:hello sirnoname sorry but I'm Italian and I do not understand what I've written ...
These values are ok , you can for'exemple put 1 500 000 for maximum and test. More you increase the max effect value lower you will decrease the movement.
And as Sirnoname said you can use the auto maximum setup.But don't forget after you find the right max value to uncheck it.If not and if you leave the auto maximum checked the movement will be lower minutes after minutes when playing.
Re: Assetto Corsa
Postby pippo23010 » Sun 17. Jan 2016, 17:01
oki boys I changed profile and it worked
thank you
pippo23010
