Bass Shaker Plugin  Topic is solved solved with post #19108
Re: Bass Shaker Plugin
Postby seppel » Sun 6. Dec 2015, 10:44
I got a question about the connection to the pc. I use a amp with 2 4ohm bass shakers connected correctly! I connect the amp to notebook stereo jack. I set up bass shaker correctly in converter software with no succsess. So i try to use a small usb-soundcard (like a usbstick) and shakers work fine. What is wrong with my notebooksoundcard (yes, drivers are up to date) .
Can somebody help me?
Best regards
Seppel
seppel
Images: 34
Postby warlock1980 » Sat 26. Mar 2016, 17:15
Does the Buttshaker plugin work in the free version of x-sim? In my Force Profiler it's not listed in the found plugins
warlock1980
Re: Bass Shaker Plugin  Topic is solved
Postby sirnoname » Sat 26. Mar 2016, 17:27
You must use latest X-Sim software, The extractor comes with many different shaker plugins.
Currently there are some interests in the 8 channel version, do you have such a setup?
Been thanked: 128 times
Postby rpower » Sat 26. Mar 2016, 18:18
sirnoname wrote:You must use latest X-Sim software, The extractor comes with many different shaker plugins.
dear sirnoname
thx for support
i ve just bought buttkiker wireless kit ?
may i ask some questions?
- i have xsim 3dof with xsim sw
- do xsim sw control also basshaker like mine or i must buy * sw?
- xsim 3dof and buttkicker may work together?
- in whick way i can configure buttkicker with xsim for games like iracing assettocorsa project and ravceroom
- in which way i can update my xsim software
thx for your support
rpower
Postby warlock1980 » Sun 27. Mar 2016, 21:19
I downloaded the free version under software. But the shaker plug in isn't listed in the plug in list in my profiler
But I misunderstood that the new one is called converter and not profiler
The 4 support
warlock1980
Postby sirnoname » Mon 28. Mar 2016, 11:40
No, all plugin dll must be shown on right side in interface setup. You may try the installer with admin rights?
On right side open the shaker plugin and select sound card.
Postby ferny » Thu 22. Mar 2018, 13:50
Dear Sirnoname, hope U could help me
I have bought the X.Sim license and using with my motorized platform, still tuning it with Your fantastic software.... I have also a Buttkicker thmp1 and have always used only with the signal center/sub coming from the sound card (sloundblaster z), now I'm wondering if is possible to perform it using X-Sim....
Consider that I play only with Oculus so I use the oculus sound earphones, so what should I do to set up the Buttkicker and X-Sim?
My games are Assetto Corsa and Project Cars 2.
Thanks for Your help in advance.
Best regards
Fernando
ferny
Postby zoinx » Sat 31. Mar 2018, 15:53
hi....use onboardcard and oculus..its enough for use this software for buttkikersetup.....or neded 2 sound cards..?
thanks in advance...
zoinx
Postby Adik » Mon 2. Apr 2018, 10:07
You need 2 soundcards
Adik
