Access Violation 3DSIMGT
Postby Hmaia » Sun 23. Dec 2012, 01:48
After following the video tutorial for 3DSimforceGT, and I start SimGt, I am getting a message "Access Violation..", repeated several times, like a spread deck of cards.
Using Wni XP Service Pack 3, running under administrator privileges, X-Sim 3.0.07.
Anyone experienced this, and what was the fix?
Hmaia
Images: 22
Re: Access Violation 3DSIMGT
Postby sirnoname » Sun 23. Dec 2012, 02:19
I know this if you have the executable in another directory without the 3DS subdirectory.
Maybe the link you have created is wrong, start it directly out of the x-sim directory.
Postby Hmaia » Sun 23. Dec 2012, 19:38
Thank you.
I have 3DS and the 3DSimforceGT executable in the same directory: " SimforceGT-Simulator." The link was created when X-Sim was installed.
I tried to start the executable from inside the directory with the same result. I will try to follow the tutorial step-by-step to make sure I haven't missed anything.
Hmaia
Images: 22
Postby sirnoname » Sun 23. Dec 2012, 20:38
-> Topic moved to the plugin section.
You have to tell me your window setup, which language, which version, graphic card etc. ...
The error tells you that the 3DS datas are not found.
Postby Hmaia » Mon 24. Dec 2012, 04:33
Hello simoname,
Thank you very much for your help.
X-Sim is installed in driver F:
Here are all specs of my computer
Copy of 3DS folder
Controllers Display
Standard floppy disk controller
Primary IDE Channel [Controller] (3x)
Secondary IDE Channel [Controller] (3x)
Standard Dual Channel PCI IDE Controller (3x) NVIDIA GeForce GTX 260 [Display adapter]
Hanns.G HZ251H [Monitor] (25.5"vis, s/n 020TG3AY00078, May 2010)
Bus Adapters Multimedia
Standard Enhanced PCI to USB Host Controller (2x)
Standard OpenHCD USB Host Controller (5x) Realtek High Definition Audio
Virus Protection [Back to Top]
Group Policies
PC Cleaner Pro
Virus Definitions Version Up To Date
Realtime File Scanning Off
avast! Antivirus Version 5.0.117441968
Realtime File Scanning On
None discovered
Communications Other Devices
1394 Net Adapter
↑ ASUS 802.11n Network Adapter
primary Auto IP Address: 192.168.0.103 / 24
Gateway: 192.168.0.1
Dhcp Server: 192.168.0.1
Physical Address: 20:CF:30:A2:6B:B5
Networking Dns Servers: 75.75.75.75
75.75.76.76
Texas Instruments OHCI Compliant IEEE 1394 Host Controller
HID-compliant consumer control device
HID-compliant device (2x)
Logitech G25 Racing Wheel USB
Logitech G25 Racing Wheel USB (HID)
Logitech Virtual Hid Device (2x)
USB Human Interface Device (3x)
HID Keyboard Device (2x)
HID-compliant mouse (2x)
USB Composite Device
USB Root Hub (7x)
Operating System System Model
Windows XP Home Edition Service Pack 3 (build 2600)
Install Language: English (United States)
System Locale: English (United States)
Installed: 3/24/2011 2:32:27 AM Gigabyte Technology Co., Ltd. GA-MA790X-UD4P
Enclosure Type: Desktop
Processor a Main Circuit Board b
2.80 gigahertz AMD Athlon 7850 Dual-Core
256 kilobyte primary memory cache
512 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded Board: Gigabyte Technology Co., Ltd. GA-MA790X-UD4P
Bus Clock: 200 megahertz
BIOS: Award Software International, Inc. F4 04/21/2009
Drives Memory Modules c,d
640.13 Gigabytes Usable Hard Drive Capacity
491.49 Gigabytes Hard Drive Free Space
ATAPI iHAS124 B [Optical drive]
3.5" format removeable media [Floppy drive]
WDC WD6401AALS-00L3B2 [Hard drive] (640.13 GB) -- drive 0, s/n WD-WCASY5130791, rev 01.03B01, SMART Status: Healthy 3328 Megabytes Usable Installed Memory
Slot 'A0' has 2048 MB
Slot 'A1' has 2048 MB
Slot 'A2' is Empty
Slot 'A3' is Empty
Local Drive Volumes
c: (NTFS on drive 0) * 41.94 GB 152 MB free d: (NTFS on drive 0) 104.86 GB 69.42 GB free
e: (NTFS on drive 0) 262.15 GB 231.24 GB free f: (NTFS on drive 0) 231.19 GB 190.67 GB free
* Operating System is installed on c:
Hope this is not too big.
Hmaia
Images: 22
Postby Hmaia » Sat 2. Feb 2013, 00:51
I have uninstalled and reinstalled X-Sim 30.0.7b and when I try to start SimforceGt, after following the training video,
I am still getting an access violation warning. It seems that both the shortcut and the executable in the SjmforceGt folder are directing me towards the Rock-and Ride simulator, instead of Simforce. On the top of the box with the access violation warning the title refers to Rock-and Ride simulator. The message inside the box reads:
"Zugriffsverletzung bei Adresse 004A1544 in Modul "SimForceGT.exe'.
Lesen von Adresse O00OO1EO.
I am trying to work with profile creation and experimenting with the software while I am getting ready to start the build.
Thank you very much for any help to solve the issue.
Hmaia
Images: 22
Postby NeoTokyoNori » Fri 1. Mar 2013, 16:44
Hello,
I have been having exactly the same problem as this, so if you managed to solve this problem
I would really like to know too!
Please do tell :)
NeoTokyoNori
Images: 12
Postby Hmaia » Fri 1. Mar 2013, 19:58
Hi there,
I have not found a solution yet. I will try to download the latest version of X-Sim and see if the problem persists.
I will also try it with a different computer. I would love to be able to start working with profiles while I am getting ready to build the simulator.
If I can get it to work, I'll let you know what worked.
Hmaia
Images: 22
Postby Hmaia » Sun 3. Mar 2013, 07:29
No luck with X-Sim 09 Beta. Crashes when Extractor is double clicked. "Entry point K32EnumProcessModules could not be located in the dynamic link library KERNEL32.dll"
Hmaia
Images: 22
Postby sirnoname » Sun 3. Mar 2013, 11:17
There is a answered thread about that extractor problem that was caused by vs2010 and 3.0.0.8 and up.
If you need a extractor workaround you have to pm me, else this will be fixed in 3.0.1.0
This does not include the simforce GT simulation, there is no bugtraker ticket and it will therfore not fixed.
