Joystick mode
Joystick mode
Postby Simulatorkc » Fri 4. Sep 2020, 10:02
Hi everyone, I have a problem with joystick mode. The "try send data" button no longer exists in the new version of xsim. I select the game, I select the controller, I press play game, the game starts but after a few seconds the extractor stops. The joystick is present in the converter. The game is ride 3 and there is no plugin. I wanted to use the simulator in joystick mode but I can't figure out how to do it. Any help? Thank you all! Denis
Simulatorkc
Re: Joystick mode
Postby sirnoname » Sat 5. Sep 2020, 20:01
Check for closing launcher apps of your game. There is an option if you enter "launcher:" as parameter with launcher exe file and the game exe which is searched for found in the task manager.
https://www.x-sim.de/documents/Howto-ga ... cripts.txt
You can also simple enter notepad as your game or use the test tablet to insure the converter does not stop.
Users browsing this forum: No registered users and 46 guests
