Project CARS 2 & Automobilista 2
Postby mreiner » Sun 12. Apr 2020, 15:20
Is there any chance, to have an updated plugin for Project CARS using the new data-structure as to be found here https://www.projectcarsgame.com/project-cars-2-api/
I know both games work fine with the PCars 1 plugin, but as I'm also using the SimHub program, that's using the PCars 2 Shared Mem, it would be great, to be able to use it with x-sim simultaniously.
thanks,
Martin
mreiner
Images: 22
Been thanked: 15 times
Re: Project CARS 2 & Automobilista 2
Postby sirnoname » Mon 13. Apr 2020, 09:30
If you can test it, no problem.
I need the exact folder where the executable is installed, the steam id of a desktop link and maybe a launcher .exe dependency.
hmm, V8 is already used but the $pcars2$ scan not.
Are you talking about patch5 stuff?
Postby mreiner » Tue 14. Apr 2020, 10:15
Hi
Thanks, for sure I can test it.
I guess about the patch5, but the important thing is the $pcars2$ mem-filename. Otherwise I think its the same as for the existing Pcars 1 plugin.
Ingame you can choose if you wan to use the PCars 1 or PCars 2 version of the shared memory. - and I'd need the PCars 2
For both games there are 2 .exe files (pCARS2.exe|pCARS2AVX.exe and AMS2.exe|AMS2AVX.exe) that's automatically choosen based on CPU capabilities.
On modern system the AVX version should be the standard.
Project Cars 2:
SteamID: 378860
Installation: %steamfolder%\steamapps\common\Project CARS 2\pCARS2AVX.exe
Automobilista 2: (new game using the same Engine - currenlty early access)
SteamID: 1066890
Instllation: %steamfolder%\steamapps\common\Automobilista 2\AMS2AVX.exe
Thanks,
Martin
PS: In another post I asked for an updated source-code template for profiles, that will compile on a recent Visual Studio version. Any Info on this?
mreiner
Images: 22
Postby sirnoname » Sun 19. Apr 2020, 16:00
please check the funktion and the autowizard detection of the games.
ps. There is a porting of X-Sim to newest VS. The result is a install party for the missing MFC redistributable, so it is not released. It seems, it cannot compile static MFC anymore.
Postby mreiner » Tue 21. Apr 2020, 20:36
Thanks a lot.
I just did some testing, and now I'm really confused.
Testing the new profile-version:
When using ingame Shared mem version of PCars 1, everything was fine as before
When using ingame Shared mem version of PCars 2, motion was there, but just not right.
So I switched back to the previous plugin-version (1.0.0.5), I had installed, and suddenly it's also working with PCars 2 Shared Mem, which was definetly not the case one week ago. I've tried this many times.
I'll do some more testing on another computer, but currently I just don't get it.
At least everything is working here for the moment.
Thanks for your effort so far,
mreiner
Images: 22
Postby sirnoname » Tue 21. Apr 2020, 21:41
Yes, you are right, the old one has already pcars2. Did not see that. It search first pcars, if not there is search pcars2.
Postby mreiner » Thu 23. Apr 2020, 15:16
OK, than I guess the error was on my side. Maybe I wasn't really using the latest Version before.
Really sorry for causing this confusion.
thanks,
Martin
mreiner
Images: 22
Postby donaldbond » Tue 5. May 2020, 19:12
i use this project cars V5 plugin and it works well less than shake gear effect, i have no data on value 23.
is there a solution to this?
thanks
donaldbond
