Xsim - Simhub
Xsim - Simhub
Postby zapata » Mon 2. Apr 2018, 22:28
Good, anyone knows what parameter you have to modify in dirt3 to extract telemetry by another port other than 20777? I want to use xsim and simhub but I can not do it since they can not use the same port
zapata
Re: Xsim - Simhub
Postby sirnoname » Tue 3. Apr 2018, 03:31
There is no more need for this. You can use the latest F1 2018 plugin out of the forum.
Re: Xsim - Simhub
Postby zapata » Tue 3. Apr 2018, 10:02
sirnoname wrote:There is no more need for this. You can use the latest F1 2018 plugin out of the forum.
Hello sirnonamme, is there a possibility to change port 20777 xsim by another different to receive the telemetry of the game? From simhub for example I can receive the data by 20777 and forward it to 20778 for simhub and 20779 for xsim, that way I could use both at the same time
zapata
Re: Xsim - Simhub
Postby sirnoname » Tue 3. Apr 2018, 18:00
Choose plugin, in the taskbar is the software minimized. Use this proxy. It is delayfree.
Re: Xsim - Simhub
Postby zapata » Wed 4. Apr 2018, 11:47
I am trying to configure f1 2017 for telemetry but I can not receive telemetry, I am using outsimDirt2 with port 20777, am I doing something wrong? what is the correct configuration in hardware_setting, thanks
zapata
Re: Xsim - Simhub
Postby sirnoname » Wed 4. Apr 2018, 12:39
Do you use the latest plugin?
You can start the outsim without X-Sim to check the telemetry data.
Re: Xsim - Simhub
Postby zapata » Wed 4. Apr 2018, 12:55
sirnoname wrote:Do you use the latest plugin?
Well I do not know if it will be the last one, I'm running the one that comes by default in the installation of xsim
zapata
Re: Xsim - Simhub
Postby sirnoname » Wed 4. Apr 2018, 13:16
That is not the last one. Use the forum search and type f1 2017.
Re: Xsim - Simhub
Postby zapata » Wed 4. Apr 2018, 13:25
sirnoname wrote:That is not the last one. Use the forum search and type f1 2017.
I guess it will be the adjunct outsimDirt2.zip that you put in another thread
zapata
Re: Xsim - Simhub
Postby spyderwash » Wed 4. Apr 2018, 16:21
spyderwash
