Video Plugin  Topic is solved solved with post #17921
Postby novoum » Mon 2. Nov 2015, 07:59
I would like to use video plugin and Joystick to generate motion data.
I selected video plugin in X-Sim Extractor, but it seems that I can't get
video plugin parameter window.
Mario
novoum
Re: Video Plugin
Postby OpaRichard » Thu 26. May 2016, 13:59
Hi Mario.
I am trying the same but cant get the video editor to output data to my arduino or simulator screen.
are you any further with this?
OpaRichard
Re: Video Plugin
Postby sirnoname » Thu 26. May 2016, 14:15
Explanaition of your setup is missing. Screenshots, setups, what do work already ...
Re: Video Plugin
Postby OpaRichard » Thu 2. Jun 2016, 21:15
Setup is blank install of xsim and a arduino mega 2560 wich is correct recognized by xsim.
I currently don't have any hardware attached on to it. I can see changes when i use the sliders. but when i use the video editor and start movie and put some rumble on as data on it, nothing seems to be send to the arduino.
Cant find a step by step manual on how to set this up, what can i do to make this work the easiest way???
Reggards Richard (i am not a gamer)
OpaRichard
Re: Video Plugin
Postby sirnoname » Thu 2. Jun 2016, 22:18
As told you, you must write which steps you did. I can then tell you where a step is missing.
Start with some screenshots of your extractor setup. Game properties etc.
Re: Video Plugin
Postby OpaRichard » Fri 3. Jun 2016, 12:20
sirnoname wrote:As told you, you must write which steps you did. I can then tell you where a step is missing.
I just did a clean install again of x-sim.
I cant figure out wich program(s) do i need to start to make use of the video editor to get working on a VR Simulater ??
I dont know how to set up anything (just to many options)
i did have uploaded the arduino driver for x-sim.
OpaRichard
Users browsing this forum: No registered users and 74 guests
