New Dirt Rally Available!
Re: New Dirt Rally Available!
Postby peguibaud » Sat 2. May 2015, 20:31
@Lost:
I needed to change the config file in 2 places, the game folder and user profile found here:
C:\Users\<username>\Documents\My Games\DiRT Rally\hardwaresettings
I see input values changing now, and about to test :)
peguibaud
Postby Lost » Sat 2. May 2015, 21:24
peguibaud wrote:@Lost:
Thanks for the help, but still it does not work
I also tried this time to change the xml file in the system folder
of the game C:\Program Files (x86)\Steam\steamapps\common\DiRT Rally\system\hardwaresettings ...
and even scanned C:\Users\lost\Documents\My Games\DiRT Rally\hardwaresettings.
I tried first with the plugin codemaster
motion enabled = "true" ip = "127.0.0.1" port = "20777" delay = "1" extradata = "1"
and then with the plugin lfs
motion enabled = "true" ip = "127.0.0.1" port = "4123" delay = "1" extradata = "0"
but no movement ... :?
Lost
Postby peguibaud » Sun 3. May 2015, 00:12
Too bad - was hoping it would help you, as I now have it working using the lfs plugin and same line you are using with port 4123 (changed in hardware_settings_config.xml in both folders).
peguibaud
Postby Mertensbart20 » Sun 3. May 2015, 09:07
Hello Lost,
Are you sure you start Dirt Rally correctly via X-sim extractor? You have to add a paramater in extractor when you start Dirt Rally because it is a Steam game. You can find this parameter by making a desktopshortcut for Dirt Rally via Steam and then look at the properties of this desktopshortcut. There you can copy a parameter which you have to add in the extractor for starting up Dirt Rally.
Hope this makes some sense. I'm not at my gaminglaptop so I can't show you any printscreens right * But I assure you it works. Let me know if you can't figure it out. Then I'll show you some printscreens from my gaminglaptop.
Greetings and good luck,
Bart
Mertensbart20
Postby Lost » Sun 3. May 2015, 12:36
@peguibaud Thanks for your help ;)
The problem, was the link in steam extractor as reported by @Mertensbart20 that thank you very much!! ;)
Now it works great with your help !! :)
Lost
Postby Mertensbart20 » Sun 3. May 2015, 21:21
hello Lost,
Good to hear you got it working. For other readers, you can find below two printscreens of what I meant earlier for starting up a steam game via extractor.
Greetings,
Bart
Mertensbart20
Postby RafBR » Mon 25. May 2015, 02:34
Does anyone use roll effect? I am using lfs plugin and roll does not work, weird things happen.
Wondering if codemasters plugin could solve it..
RafBR
Images: 24
Postby Mertensbart20 » Mon 25. May 2015, 09:40
Hello Raf,
I use the roll effect and it works fine. But I believe the center is not at zero. I think it is at 900 000 if I remember correctly and I use as upper and lower levels 750 000 and 1050 000. I'm not 100% sure about these values since I am not at my gaming laptop. But I am sure the center is not at zero and that this probably your problem.
I'll send you my settings as soon as I am back at my gaminglaptop.
Greetings,
Bart
Mertensbart20
Postby Mertensbart20 » Mon 25. May 2015, 12:56
Hello Raf,
In the attachment you can see my settings for the roll. The centervalue is 9 000 000 and my minimim is 7 500 000 and maximum is 10 500 000.
Greetings,
Bart
Mertensbart20
Postby Mertensbart20 » Sun 7. Jun 2015, 22:29
Hello everybody,
Here you can find a video of my 3DOF simulator working with Dirt Rally:
https://www.youtube.com/watch?v=y6pzZgh ... e=youtu.be
Greetings,
Bart
Mertensbart20
