New Dirt Rally Available!
Postby RafBR » Tue 28. Apr 2015, 04:02
There is a new Dirt Rally available and it seems to have giant potential with new physics/tyre model/terrain model...
I found this thread about telemetry and shared memory but I was not able to test the game with dirt plugin:
http://forums.codemasters.com/discussio ... ry-feature
and the link for the game news and gameplay:
http://forums.codemasters.com/discussio ... ly-out-now
My regards,
Rafael
RafBR
Images: 24
Re: New Dirt Rally Available!
Postby sirnoname » Tue 28. Apr 2015, 07:32
did you also use the l4s plugin?
Postby RafBR » Tue 28. Apr 2015, 15:14
Hello sirnoname,
I meant had not time to test it, not that it is not working with dirt plugin.
I will try as soon as possible with both plugins!
Thanks,
Rafael
RafBR
Images: 24
Postby Mertensbart20 » Wed 29. Apr 2015, 17:25
Hello guys,
I installed Dirt Rally and it makes the following file directory ""my documents"->"My Games"->"Dirt Rally"->"hardwaresettings" and in there you can find "hardware_settings_config.xml" and edit it as follows:
motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
I was also able to start Dirt Rally from extractor. Unfortunately Dirt Rally needed to be updated but the steamserver was busy so the game could not be started. But till there it looked good. I'll give a new try this evening.
From what I know now I would say Dirt Rally will give motion data and will be compatible with X-sim.
Greetings,
Bart
Mertensbart20
Postby sirnoname » Wed 29. Apr 2015, 20:26
You can make a autoscan which change new hardware conf files.
If you give me the exe file name, I will make a script for that game for autodetection, its not difficult.
I am very sure the codemaster plugin will work ;)
Postby Mertensbart20 » Wed 29. Apr 2015, 21:59
Hello sirnoname,
Thanks for the offer but I think I have it working. For now there is a server error 41 which you can find here:
https://steamcommunity.com/app/310560/d ... 327297654/
Due to this error I can't start the game for the moment. As soon as it is solved I'll try to get my simulator working with Dirt Rally and post some videos.
Greetings,
Bart
Mertensbart20
Postby grancab » Thu 30. Apr 2015, 14:33
drt.exe
the route is: C:\Program Files (x86)\Steam\steamapps\common\DiRT Rally
grancab
Postby Mertensbart20 » Sat 2. May 2015, 13:12
Helo everybody,
I got the gaming working again.As I expected there is motion data and I got my simulator working with Dirt Rally using the same profile from Dirt 2 (LFS profile for extractor). Looks very good by the way.
Greetings,
Bart
Mertensbart20
Postby scottlolo » Sat 2. May 2015, 19:00
DIRT RALLY
Plugin DIRT2
motion enabled="true" ip="127.0.0.1" port="20777" delay="1" extradata="1"
good work ,no crash
scottlolo
Images: 5
Postby Lost » Sat 2. May 2015, 19:57
I do not work with either plugin ....
I tried using the plugin lfs and codemaster editing the xml file
I tried searching the game automatically and can not find it then I added the exe "drt.exe" in manual work and even ...
Lost
