The Crew PC
The Crew PC
Postby magicfr » Wed 3. Dec 2014, 10:46
Hello,
Here the documentation for The Crew output telemetry :
https://docs.google.com/document/d/1Mbe ... sp=sharing
If I have time I'll code a pluging for X-Sim myself.
Cheers,
Seb
magicfr
Re: The Crew PC
Postby Wanegain » Wed 3. Dec 2014, 16:32
You rock !
Wanegain
Re: The Crew PC
Postby Mertensbart20 » Fri 2. Jan 2015, 16:20
Hello Seb,
Thanks for the output telemetry. I have a 3DOF-simulator myself which you can see here:
https://www.youtube.com/watch?v=92PAlG_RpSo
It is not quite clear how to read out the telemetry values. Are you accessing memory values?
Thanks in advance,
Bart
Mertensbart20
Re: The Crew PC
Postby kbmaugustijn » Sat 7. Feb 2015, 22:13
For everyone who wants motion out of The Crew, use the life for speed plugin. Then change the port info in the extraconfig file from 1337 to 4123. Downside of this is you can only use pitch roll yaw. Other telemetry data will not work. Until someone writes a plugin that uses port 1337 u can use this solution.
kbmaugustijn
Re: The Crew PC
Postby Mertensbart20 » Sat 7. Feb 2015, 22:37
Hello kbmaugustijn,
Thanks for the tip. You are talking about pitch, roll and yaw. Does it give the orientation of each axis and also the speed of the axis? If this is the case it is still very interesting. I have no copy of The Crew so I can't test but I will certainly get one if orientation and speed is given. Could you maybe post a small video where you can see the changing values?
Thanks in advance,
Bart
Mertensbart20
Re: The Crew PC
Postby kbmaugustijn » Mon 9. Feb 2015, 19:35
Hey Bart,
here is a short video of outsim, converter and ingame (it's a bit blurry sorry). Longitudenal and lateral don't work because they are connected to orientation. if you're driving east the forces are correct but if you go west the forces are reversed :? pitch roll and yaw seem to work perfectly (in like city's little pitch while driving on mountain roads lot of pitch/roll).
Kevin
kbmaugustijn
Re: The Crew PC
Postby Mertensbart20 » Mon 9. Feb 2015, 20:43
Hello Kevin,
Thanks for the video. Can't you use the acceleration for X, Y and Z determine the speed of the actuators?
And with the reversing of the longitudinal an lateral forces, can't you use the X-map orientation (or Y-map or Z-map) to detect when the reversing occurs? If so you can program a controller like an arduino to take the reversal into account.
Greetings,
Bart
Mertensbart20
Users browsing this forum: No registered users and 46 guests
