extracting motion data form FUEL (codemaster)
Postby Mertensbart20 » Mon 23. Dec 2013, 11:43
Hello everyone,
I was wondering if anyone had experience with extracting motion data from the codemaster game FUEL. The video below proves FUEL sends out motion data.
http://www.youtube.com/watch?v=5dzsDohn9kE
Does anyone know if it works the same way you extract motion data from Dirt 2 and 3 and the formula 1 games from codemaster?
Thanks in advance,
Bart
Mertensbart20
Re: extracting motion data form FUEL (codemaster)
Postby sirnoname » Mon 23. Dec 2013, 14:47
yes, only the wizard script is missing. X-Sim should change the hardware cfg file with using the wizard, but not tested so far.
Postby Mertensbart20 » Mon 23. Dec 2013, 23:51
Hello sirnoname,
Do you mean than that you can use the live for speed plugin and change the file hardware_settings_config.xml as follows:
motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0"
That wizard script is missing can be solved by adding the game manually. Do you agree with my analysis?
Thanks in advance,
Bart
Mertensbart20
Postby sirnoname » Tue 24. Dec 2013, 03:18
yes to all, lfs plugin or codemaster plugin (dirt2).
Postby Mertensbart20 » Tue 24. Dec 2013, 14:20
Thanks for the answer
I see that you are an administrator so maybe you can help me with adding platform-drawings on x-sim. Last year I build this platform:
viewtopic.php?f=37&t=335
I would like to upload the technical drawings but the whole project is 20MB and I think that is to big for X-sim. Can you tell me how I can share my drawings with other X-simmers?
Thanks in advance,
Bart
Mertensbart20
Postby Mertensbart20 » Sat 11. Jan 2014, 18:34
Hello everybody,
After some searching I have to conclude that it is not possible to extra motiondata form FUEL using the LFS-profile or using the graphic driver in the extractor.
I assume that you can find motiondata in the memory output somewhere but that goes a little bit to far for me. Should anybody find another solution, please add this to this forumtopic.
Greetings,
Bart
Mertensbart20
Users browsing this forum: No registered users and 42 guests
