f1 2015  Topic is solved solved with post #20412
Re: f1 2015
Postby whoracle » Wed 9. Nov 2016, 21:23
I got it running, I didn't know that after I had made a profle of F1 2016, I had to make this adjustments in the motion driver setup:
It took me 3 evenings to discover that, but I am familiar with the x-sim interface *
whoracle
Re: f1 2015
Postby tiopepe » Sun 11. Dec 2016, 00:57
I bought F1 2015 and I have istalled it.
I have updated list of the game in X-sim extractor: now F1 2015 is available in my list.
When I start the game from extractor (play game button), F1 2015 start well, but I see a window with error message :"x-sim is waiting for the game F1_2015(steam) and its executable F1_2015.exe".
I think that I use correct script (F1 2015 steam.txt):
title: F1 2015 steam startup exchange
games: F1 2015 (steam)
search_executable: F1_2015.exe
game_parameter: steam://rungameid/286570
unicode: no
mustdir1: steam
notdir1: demo
plugin: Dirt2plugin.dll
Dirt2plugin.dll in my folder is Sep 25 2013 version
In this condition Outsimdirt2 (installed Aug 06 2015 version) started correctly, and my converter works fine for 10-15 minutes, after this time, input setup values in converter They do not change (frozen) but values in outsimdirt2 changed (updated from the game). I don't know if this problem is correlate with the error message.
In any case I would like to use x-sim more than 10-15 minutes
can you help me?
thanks in advance
tiopepe
Re: f1 2015
Postby sirnoname » Sun 11. Dec 2016, 01:34
Try to use the autodetection with the plgin driver. There you can add your executable and a profile. You do not need the play game button but you need to use the taskbar icon switched to green.
Re: f1 2015
Postby tiopepe » Sun 11. Dec 2016, 01:46
I don't know driver plugin: where I can set "autodetection"?
tiopepe
Re: f1 2015
Postby sirnoname » Sun 11. Dec 2016, 01:52
top post of this page and task bar icon.
http://www.x-sim.de/manual/autoscan.html
Re: f1 2015
Postby tiopepe » Sun 11. Dec 2016, 02:14
ok,
now taskbar icon switched to green.
when I try to edit a row in autoscan setting appear this error message: "no profiles found for this executable. you have to insert some profiles for the local database"
tiopepe
Re: f1 2015
Postby tiopepe » Sun 11. Dec 2016, 16:07
whoracle wrote:I got it running, I didn't know that after I had made a profle of F1 2016, I had to make this adjustments in the motion driver setup:
Hi whoracle,
I have same issue with F1 2015:
could you explain me how did you add "F1 2016" in list of autoscan setting? (based your motion.png pictures)
because when I try to edit a row in autoscan setting appear this error message: "no profiles found for this executable. you have to insert some profiles for the local database"
thanks in advance
tiopepe
Users browsing this forum: No registered users and 54 guests
