Re: Assetto Corsa
Postby jomaho » Tue 1. Jul 2014, 18:20
Shared memory layout has changed with update .20 I'm not a programmer but could this be the reason we lost motion? :?:
http://www.assettocorsa.net/forum/index ... ence.3352/
jomaho
Re: Assetto Corsa
Postby gabry1090 » Wed 2. Jul 2014, 10:40
I'm afraid so...who did the assetto corsa plugin? how can we solve the problem? thanks in advance ;)
gabry1090
Re: Assetto Corsa
Postby Balles » Sun 6. Jul 2014, 10:04
Up !
Is someone able to update the AC plugin with the new shared memory ?
I'd be happy if someone can say at least yes / no / maybe / in a near future or whatever.
Thank you.
Balles
Re: Assetto Corsa
Postby sirnoname » Sun 6. Jul 2014, 23:11
There is a new plugin. If you like we can test it and finalize it. I hope you are a good driver ;)
Say a day and time (GMT+2).
Re: Assetto Corsa
Postby sirnoname » Tue 8. Jul 2014, 18:57
Ok, seems there are no interrest in assetto
Re: Assetto Corsa
Postby spyderwash » Tue 8. Jul 2014, 19:25
I am very interested but do not have the ability to fix
spyderwash
Re: Assetto Corsa
Postby gabry1090 » Tue 8. Jul 2014, 19:31
sirnoname wrote:Ok, seems there are no interrest in assetto
i'm interested too and as i told you yesterday in private message i will help you if you need to test the plugin with my simulator
gabry1090
Re: Assetto Corsa
Postby sirnoname » Tue 8. Jul 2014, 19:44
I changed the detection of the game for the Game wizard. So you have to use the X-Sim registry cleaner and press the extractor button. After this you have to enter again the forum user. After you did this, close the extractor and extract and copy this files:
Copy_to_plugin_folder.zip
(732.71 KiB) Downloaded 2938 times
Then delete all assetto entries in left extractor box and do a wizard autoscan again. I need this verification for correct detection.
The steam version should be detected with a app id in the properties of the game (left box).
After starting the play game button must stay blue.
Then I need verification off all accelerations.
Last but not least I need verification of the effect 93 to 96. Should be tire slip but I do not know how to verify which number is which wheel :(
Re: Assetto Corsa
Postby spyderwash » Tue 8. Jul 2014, 20:38
a great big thank you tonight but tomorrow I can try with my 3 dof which wheel
thank you
spyderwash
Re: Assetto Corsa
Postby gabry1090 » Tue 8. Jul 2014, 21:16
thanks, if i'll be back not to late i'll try main forces tonight or at least tomorrow, can't try others beacuse i only have 2dof simulator, he will help us spiderwash with these! thanks again
gabry1090
Users browsing this forum: No registered users and 28 guests
