Access Violation 3DSIMGT
Re: Access Violation 3DSIMGT
Postby NeoTokyoNori » Sun 3. Mar 2013, 16:21
Hmaia wrote:No luck with X-Sim 09 Beta. Crashes when Extractor is double clicked. "Entry point K32EnumProcessModules could not be located in the dynamic link library KERNEL32.dll"
I tried X-Sim 09 Beta, and I still have the same issue with SimForceGT access violation :(
on Windows 8 64-bit.
NeoTokyoNori
Images: 12
Postby Neoradix » Wed 22. Oct 2014, 21:50
is this a dead issue, i am also getting the same deck of cards (errors)
Neoradix
Postby sirnoname » Thu 23. Oct 2014, 00:19
Yes, error is known and cannot be fixed. Som computer work, some not. We cannot reproduce here.
Postby djchamikara » Sun 10. May 2020, 20:24
If you are getting an error "zugriffsverletzung bei adresse 005fb428 in Modul 'SimforceGT.exe'. Lesen von Adresse 000001E0", when you are trying to open "SimforceGT-Simulation" tool, This is the solution.
You should set the "Regional Format" to "English (Germany)". Then it worked.
1. Type "region settings" in start menu.
2. Then open "Region settings". It will open a new window.
3. There is a dropdown list under "Regional Format" topic.
4. From the dropdown list, select "English (Germany)"
5. That's all.
This worked for me (my operating system is Windows 10).
djchamikara
Users browsing this forum: No registered users and 54 guests
