X-Plane 10  Topic is solved solved with post #10805
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 04:28
in 4 years with x-sim i only played car games, now i want to try x-plane, i got a racingseat scn5 150mm, i did find some profile that seam to fit ,it ask left, right , but i got noting
for now i only got the demo ,does it make a difference?
is there someting i need to put in plugin of x-plane , i did
It someone can help
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 05:52
my simulator work with all other car games.
When i clic play game on the extractor, the button stay grey, x-plane start, i clic start on the converter, it turn red, everiting seam normal.
When i close x-plane the red start button stop turn blue again
But i got no motion at all.
using the demo verion so far
thanks
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 07:07
i did buy the full version, still no lock
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 17:29
when i run the autosearch in the extractor, it do not find it, i have to instal it manualy maybe i do someting whrong,? Is there someting to whrite in call parameter?
thanks
lyspatriote
Re: X-Plane 10
Postby sirnoname » Tue 22. Dec 2015, 19:42
The play game button must stay grey, else inform yourself about the launcher paramter.
Also the setup in xplane must be as written here incl. new plugin.
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 21:52
Thank a lot Sirnoname you help me so many times in the past. wish you all the best for 2016
I know the play button should stay grey, it does
Not sure what you mean by ''Also the setup in xplane must be as written here incl. new plugin.'' what the here(a missing link? info on that tread?)
about the new plugin ,it the one include in x-sim plugin folder? that i put in plugin of x-plane? i did that
by setup do you mean call parameter in extractor or a setup file in x-plane
thanks again
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Tue 22. Dec 2015, 21:56
maybe the here is the manual http://www.x-sim.de/manual/x-plane.html
im reading
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Wed 23. Dec 2015, 03:59
i try to understand , and to make ting worst my x-plane instalation is french so i need to translate
in manual
first if i got x-plane 10 ,i refer to instruction for 8.40?
when it say master server i figure it was than screen Image
when it say 03 and 16 in the instruction
i click 4 and 17 like showed on than tread for mac-g-load and pitch,roll,heading
the part when it says in the instruction:``
Always you have to insert the port and IP address in the Master Server or Motion Platform areas.
In our case this is 127.0.0.1 and portnumber 49000, which is normaly only need to be changed at X-Plane 8.40.
In some versions it might be a problem to set 127.0.0.1 because you cannot use the port 49000 twice on one computer. Then you have to use a second pc, which
i figure it was that screen
as ip i white the one it suggest on the top of the page
my profile look like this
my extractor look like this
i hope im getting closer to get it, playing video game without motion after a couple years it pointless, look like fun that game
thanks a lot
merry X-Max!
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Wed 23. Dec 2015, 04:18
also about x-plane udp motion platform packet reader
it dosent detect x-plane this one is the one you post in that tread.
Shoud i use the one in plugin folder.?
To use it i just need to double clic on it and it show the data value? do i need to do someting else
thanks
lyspatriote
Re: X-Plane 10
Postby lyspatriote » Wed 23. Dec 2015, 06:02
i change the language of x-plane
in net connection, to remplace the ip adresse that was sugested i put my ip adresse
did not change a ting , still noting
lyspatriote
