Flight Simulator X 2DOF Sabertooth/K8055 Profiler.
Postby robcoll » Wed 27. Feb 2013, 01:07
Hi I have Builded a SImulator 2 DOF ..Using information from This Forum...I have looked But I can't find a PROFILER for Flight Simulator X ....Iam in the face of trying to understand Xsim3 and how to configure the Axis and Gforces...I wish someone on this forum can help me out with this project to develop a FSX Profiler...I do Have (Skipe and Team Viewer) to facilatated setup....PLEASE Help...Thanks
This Is My Actual simulator ...
I Have Build A 2DOF WiperMotor With sabertooth/k8055..
Thanks... :D
robcoll
Re: Flight Simulator X 2DOF Sabertooth/K8055 Profiler.
Postby sirnoname » Wed 27. Feb 2013, 01:44
First you install FSUIPC, then you open FSInterrogate2std.exe and find the values you like (pitch roll).
Add the game executable to the extractor game list, select the msflightsim plugin in the plugin driver and input the values you like to use in that plugin.
If the values reach the converter you can think to make profiles with that values in the same way you do for car games. However solve this steps first.
A K8055d is not used for electric motors, it is used for pneumatic. Buy a arduino.
Postby robcoll » Wed 27. Feb 2013, 02:17
sirnoname wrote:First you install FSUIPC, then you open FSInterrogate2std.exe and find the values you like (pitch roll).
Hi Sirnoname...I will Thanks you for taking your time to reply back at me...My FSX is all ready have the later FSUCIPC4 loaded..Now Im not real good with Interfasce a programing and running plugin..some of my setup for the actual sim was don't over team viewer for the virtual company that I fly for VATSIM...I have tryed all ready to set up the two motors on the Math Page/G-force..I have not been able to make it work ..even that I have tryed msflightsim plugin. I have fallow Keven (1-2)Stage and can't make it to work property... and The only simulator load on my computer is FSX...Im not familiar with (FSInterrogate2std.exe )..I will Try to downloads this file run it and give it a try..My very Big Problem is understanding Xsim om configering the Axis/and set the pots and I don't have a profiler that I can use to test under FSX...I do have a arduino Uno if that will make it more simpler to setup...thanks
robcoll
Postby robcoll » Wed 27. Feb 2013, 02:32
Ok I do Found the FSInterrogate2std..when a run the xtractor a select the Msflightsim plugin the Peter Dowsons FsModules comes on...there is a selectable bar (show table of exportable elements/start FSInterrogate2std.exe...now I don't have a clue what iam looking for there...
robcoll
Postby robcoll » Tue 12. Mar 2013, 18:42
ok I went back and re-read the manual..for xsim as you guys know is not self explanatory the information there is more related to driving motion and not Flight simulation..any way I have manage to create a math that will control the axis..now here is the situation pots are set to max/min...as I fly it will follow the plane moments just fine...but is I do bank or pitch up hard will go into to reverse on box axis...if I keep the banking shalow it will respond right..I have tryed different limits buts it still..HELP Please Im out of knowledge or please to look on the web for help....Thanks
robcoll
