pololu board ??
pololu board ??
Postby stefanosdimos » Tue 8. Jan 2013, 17:47
i ve tried with arduino leonardo to work as mini simulator .
i want to try in real scale !!with 2 wiper motors , i wiil need 2 pololu boards ,1 for each motor !! is that right ?
i need and another board as'motherboard' something like veleman or thanos board,to fit pololu on ? i think pololu is a h-bridge for 10-15 amperes,or is used and as a motherboard ??
if i m miising something please tell me what !!
actually i wiil need 3 boards ?
thanks a lot guys
stefanosdimos
Re: pololu board ??
Postby ferslash » Tue 8. Jan 2013, 23:52
if you buy a couple of polou jr 12v12 they do all the job, they countrol the motors and they connect you to the x-sim software, so you dont need to buy another board.
there is another cheaper pololu card, i dont remember the name, that is just an h-bridge, used to only control the motors, and needs also another board to connect you to your pc, but again if you buy pololu 12v12 they do all the job
best regards
fer
ferslash
Re: pololu board ??
Postby motiondave » Wed 9. Jan 2013, 00:22
As ferslash says , pololu JRK board, one per motor , they will handle 14 v at 30 amps with heat sink on the big chip and fan cooling.
Re: pololu board ??
Postby stefanosdimos » Wed 9. Jan 2013, 10:58
thanks again !!!!
stefanosdimos
