by kveras » Tue 24. Mar 2020, 17:33
Saludos cordiales. Estoy realizando un simulador 2dof pero no he podido poder decifrar el error que me mantiene atascado por ahora. el mensaje de error es el siguiente= (error opening USO comport COM3. the comport is used by another plugin or USO entry. You may disable all interface plugins and try to clean all USO comports . Another reason clould be a disconnect of the USB line be interferences of the motor. You must also insure you are using the newest drivers.
- Attachments
Sin título.png (3.52 MiB) Viewed 2429 times
