ARDUINO Project Problem
Postby samiramadan » Fri 2. May 2014, 14:29
> hello,
> i'm new on x-sim, and my arduino and bridge is ready to run but when i
> modify my profile in converter there is no response in the game
> i'v done what this video is told :
> http://www.youtube.com/watch?v=WoaT-vL8xWA
> and the same thing as this video :
> http://www.youtube.com/watch?v=tMeeV3WWlYE
> but no response, TX and RX don't blinking at all
> i want to know what i should to do in converter specially in USO section
> help please
samiramadan
Re: ARDUINO Project Problem
Postby sirnoname » Sat 3. May 2014, 14:39
Sorry, no project details no help. You have to give some infos about used firmware, arduino etc.
Make a project post as other do.
Postby samiramadan » Sun 4. May 2014, 01:53
hello,
i'm build Arduino XPID project that you posted, my problem is , on arduino Rx is blinking but Tx is NOT
AND
in USO section what i have to do on this section ??
when i click to start the Converter, the message is :
" Error opening USO comport COM10.
The comport is used by another plugin or USO entry. You may disable all interface plugins and try to clean all USO comports.
Another reason could be a short disconnect of the USB line by interferences of the motor.
You must also insure you are using the newest drivers.(FTDI, Prolific)".
and because of this message i used " registry cleaner to make a factory default. " as you told someone before but this didn't work with my problem
and
regards
samiramadan
Postby samiramadan » Sun 4. May 2014, 01:54
i'm using Arduino Uno R3 with BTS7960b bridges with wondows 7
samiramadan
Postby sirnoname » Sun 4. May 2014, 11:26
Why do you enter something in the USO?
The linked manual tells you other, there is no word of USO. Look in the interface setup.
The error message did help you and told you your problem.
Interface setup or the extractor OBD2 setup may use the comport, so USO say no.
Remove all USO entries and OBD2 setups.
Postby samiramadan » Wed 7. May 2014, 03:36
okay
i start it and it work but there is something i have to ask about
why one LED of Tx\Rx is blinking and the other is not
samiramadan
Postby sirnoname » Wed 7. May 2014, 17:46
Why it should?
Postby samiramadan » Thu 8. May 2014, 20:21
because they blinking here in this video as my project " arduino Xpid "
both Rx and Tx is blinking >>
samiramadan
Postby samiramadan » Thu 8. May 2014, 20:35
samiramadan
Postby sirnoname » Thu 8. May 2014, 20:48
No they don't!
You have there two projects, one is XPID the other is OBD2. OBD2 blink both.
