Hello all help a newb
Postby Jabrix » Sat 22. Mar 2014, 06:03
I've been lurking online and reading a bit about the amazing projects people are completing here. I decided last October I would build a 6dof simulator. The problem is I lived in an apartment, so I've had to wait. Well my house is currently being built and should be finished by October. As soon as I get moved in I plan on getting this project started. I want the simulator to seat 4-6 people and have a budget of $6000-$10000. Is this doable?
I am having a 220v 50A outlet installed in my garage. Is this overkill as I can get a 30A instead?
Finally as I understand it the basic connection would be a 6 outlet 220V power strip connected to the 220V wall outlet and an inverter is wired into each outlet on the power strip. The inverter converts the electricity from single phase to three phase. This is wired into the motor with positional sensors which is connected to a gear box, which is connected to the frame via support rods. I'm aware I'm leaving off the wiring for the control board AMC1280USB. Is that a good overview?
I'm just trying to get a basic understand for the build. Thank you for your time. If I need to post this in another area, forgive me. I'm new here. Just let me *
Jabrix
