Start Game issue
Start Game issue
Postby jismake » Tue 5. Nov 2013, 09:11
Why would I game not start after when I hit the play button on the extractor. I have converter ON and i can see game detected on extractor and i have loaded profile. Only thing I can see when i hit the game button is "Profile stopped successfully"
I was checking quick guide to take me thru. But im stuck at this point..
please help ..
thank you
jis
jismake
Re: Start Game issue
Postby sirnoname » Tue 5. Nov 2013, 10:15
Converter has nothing to do with that problem.
Your game executable has been stoped, maybe you game use a launcher.
Tell us which game and provide a screenshot of the game main directory.
Postby jismake » Tue 5. Nov 2013, 21:10
thank you for reply.
the game is Truck Racing by Renault and screenshot is attached.
thanks,
jis
jismake
Postby yokoyoko » Tue 5. Nov 2013, 21:30
Plugin :: NSR1Plugin.dll
Create a shortcut to your RTR.exe game executable file which is located in the game directory/BIN.
Add a command line to your exe file that looks like:
“C:\...gamedirectory...\Truck_Racing_By_Renault_Trucks\Bin\RTR.exe” -config -FD_TYPE 1 -FD_ID 0xfebabece -FD_Host 127.0.0.1 -FD_Port 4123 -FD_Filter 0.95 0.95 0.95
Written in one line, do not forget the semi cons.
Can you please show us the command line of your RTR.exe shortcut?
@sir - are these "â€" signs correct or messed my firefox something up? I have no experience/never tried Truck Racing by Renault :oops: + edit: in which directory should the plugin be located?
Postby jismake » Tue 5. Nov 2013, 22:03
Target : "C:\Program Files (x86)\Truck_Racing_By_Renault_Trucks\Bin\RTR.exe" -config -FD_TYPE 1 -FD_ID 0xfebabece -FD_Host 127.0.0.1 -FD_Port 4123 -FD_Filter 0.95 0.95 0.95;
jismake
Postby sirnoname » Tue 5. Nov 2013, 22:39
Did you do a autoscan or did you insert the game by yourself?
The characteres are firefox dammeged, use "
Make a screenshot of rightclick the game in the extractor left listbox -> edit
Copy the command line here
Postby jismake » Wed 6. Nov 2013, 08:14
hello,
i have attached all screenshots.
thanks for looking into the issue.
i did do autosearch in the beginning..then it always found my game after it.
thanks,
jis
the window after ok the edit window
the error window after right click edit
Normal screen
jismake
Postby sirnoname » Wed 6. Nov 2013, 10:01
Plz use the latest version and do the screenshots again.
You do not have connection to the plugin updater and the dialog is broken because if this.
Rightclick and edit the game ...
Postby jismake » Wed 6. Nov 2013, 23:08
thank you again.
I have updated with latest version and attached is the screenshots
thanks,
jis
jismake
Postby sirnoname » Thu 7. Nov 2013, 23:59
The last game update did stop working because the game executable in the bin directory need as start directory the renault main directory.
Copy the exe into the main folder and try again ...
