Hello everyone and congratulations to the director
Re: Hello everyone and congratulations to the director
Postby juah » Sat 10. Nov 2012, 15:04
I mounted a Iconia A100
Uploaded with ImageShack.us
juah
Images: 12
Postby sirnoname » Sat 10. Nov 2012, 15:31
Hi, I had before such a double din CarPC with windows 7 but the design was not as good as with the radio and the climatronic is working not as good as with radio (FK2).
I use a 5" smartphone because I want all internet functions online, it will never sleep. It must have 8cm width and it will fit into the CD bag hole.
Do you have OBD vie BT?
Postby juah » Sat 10. Nov 2012, 15:39
Sorry if I do not understand quite what you write, use a translator :-) I also use wifi for internet with galaxy s3 OBD what?
juah
Images: 12
Postby juah » Sat 10. Nov 2012, 15:50
as you have connected the audio output tablet> speakers
juah
Images: 12
Postby sirnoname » Sat 10. Nov 2012, 15:57
I use a special mod of the radio for the android device. The original radio amplifier is always active, also if the radio is not used. So I added a input directly to the amplifier chip. The S has a aux input but cannot mix to the radio (bad for navigation with radio). This will reduce the needed place, work and power.
Postby juah » Sat 10. Nov 2012, 16:53
I used the aux output of the radio, I put the radio in the trunk so I can use the steering wheel controls and a navigation system with speakers
juah
Images: 12
