Hello + beginner questions
Re: Hello + beginner questions
Postby yokoyoko » Wed 15. Aug 2012, 15:56
With this setup: - motortravel= 60°up, 60°down - leverarm=80mm - wipermotors in angle with the upper mounting points - other dimensions orientated by your prev. post
I got the following corner-movement: left=11° - right=11°
For acceleration=6° - for braking=6
--> this
or is this to be adjusted after building a "prototyp"?
Postby motiondave » Thu 16. Aug 2012, 02:24
--> this
Too technical for me.....
Can anyone else advise?
Postby Kangapawns » Thu 30. Aug 2012, 09:08
--> this
I am not a engineer but this relates to the angle achievable going by the specs:
"motortravel= 60°up, 60°down - leverarm=80mm - wipermotors in angle with the upper mounting points - other dimensions orientated by your prev. post" That is how the motor is set-up...increasing the lever arm size will increase the final angles achieved also and can be adjusted after if you have allowed room for this in design. I allowed for the arm to be between 120-200mm ..the greater i increase my arm the more pitch and angles i achieve.
This is the final achieved results for the specs provided of what that motion sim would move like:
"I got the following corner-movement: left=11° - right=11°
For acceleration=6° - for braking=6"
I hope thats the info you where seeking
Kangapawns
Postby Kangapawns » Thu 30. Aug 2012, 11:39
bobbuilt, is this better to work out after construction though rather then setting up profiles for a sim thats not even constructed?
as values can change upon construction unless you stick 100% to the design plans.
Kangapawns
Postby motiondave » Thu 30. Aug 2012, 14:59
The profile writing is changable to suit. My big motor sim has heaps more lateral than longitudinal. I just write profiles to suit. I just increase the number in the lateral.
Users browsing this forum: No registered users and 24 guests
