installation and configuration
Re: installation and configuration
Postby sirnoname » Mon 16. Sep 2013, 23:31
Arduino is serial, it uses an USB to serial converter onboard.
Postby blaweveraldo » Wed 18. Sep 2013, 04:45
It seems that I have advanced in the configuration, the problem now is that when I click on start to start converting the motion commands to the motors appears that message and start does not start.
What should I do now?
The message is this!
(error opening uso comport 4
the comport used by another plugin or uso entry. you my disable all interface plugin and a try to clean all uso comports.
another reason could be a short disconnected of the usb line by interferences of the motor).
I'll have to mount a pc and asked me if the operating system has to be 32 or 64 bits.
What should be please.
Have a great weekend.
blaweveraldo
Images: 20
Postby RacingMat » Wed 18. Sep 2013, 10:25
You cannot run at the same time Xsim and Serial monitor !
If you follow the steps I described in my tutorial, your first tests are the following :
- pots and motors wired
- but pot not mounted onto the motors
- only Arduino Software running : load sketch into Arduino
- Xsim not running
- power on
-> turn manually the pots !
Describe what's happening ...
