Problem game NoLimits  Topic is solved solved with post #471
Postby kevin123 » Wed 30. May 2012, 22:52
As the title I can not run this game ... I downloaded some profiles but do not know which plugin to use I tried both with x-sim with both the 2.0 beta 3 and I noticed that the version I usually try 3 games automatically selects exe and run all but the no Limits does not find it I put it manually but not right
Can anyone help me?
version of the game and 1.7.1.0
thanks
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Re: Problem game NoLimits
Postby sirnoname » Sat 2. Jun 2012, 03:30
Step, by step.
First: only X-Sim 3 will be supported! No X-Sim 2 will be discussed here.
As a X-Sim 3 user you need at minimum a Stage 2 access for the memory driver and no Limit.
Which game version do you own and what are the exact steps your tried?
Postby kevin123 » Sat 2. Jun 2012, 11:48
Sirnoname Hello and thanks for your help
Then I'd use the version 3 x-sim but sometimes asks me the key and does not work offline ... and I have to reinstall the version 2 because I have read the terms of use and I sent a pm to the administrator but I still must answer to the key stage 2
The game version is 1.7.1.0
I did the steps are:
In version 3, I tried the game automatically but can not find it
I put it in manually loaded into the profile for nolimits-Force Profiler as I do with other games starts but no movement
In version 2 I start with Force Force sender injector as I read somewhere ... with these settings
But I do not see any calculation injector
But if you say that does not work with version 2 but only with the 3 stage 2 I just have to wait until he answers the admin for the keys right? or else another way to get it started?
thanks kevin
kevin123
Images: 132
Postby sirnoname » Sat 2. Jun 2012, 12:47
Hello kevin,
there is no key request at our side. As far I looked into the project section it is possible in your case. Simple make another request and do not forget your PC Code out of the activation menu.
A automatic game finder for the graphic, forcefeedback or memory driver is currently not implemented, it is only working for the official plugins.
For noLimits you must enable the memory driver and the online database button inside this dialog to find predefined offset values.
regards
SirNoName
Postby kevin123 » Sat 2. Jun 2012, 14:38
Hello Sirnoname
I sent a pm to warandpeace administrator the other day.
Today I sent you a pm and I put Sirnoname hardware id of my PC that I get into key dialog is right?
My kids can not wait to play NoLimits
Thank you very much, even by my 2 sons
Kevin
kevin123
Images: 132
Postby kevin123 » Sat 2. Jun 2012, 18:21
Hello Sirnoname
Excuse the trouble I still can not run NoLimits .... :oops:
I tell you step by step so you understand what I'm doing wrong and where I put some screenshots
1) I try the game in hand because it is not automatically
2) Select the game engine and put the settings in X-Sim Extractor
3) I open Motion Driver and I enable memory driver
4) I try the online database and load a profile for the version of my game
5) Load a profile for X-Sim NoLimits Converter edit my settings setup output engine speed dynamic
I start the game in windowed mode to see that windows works injector vertical longitudinal lateral force
Now I do not understand how to send data in X-Sim Converter for movement
Kevin
kevin123
Images: 132
Postby kevin123 » Sun 3. Jun 2012, 16:40
Solved! :D
Eventually had to read the manual x-sim 3 .... :mrgreen:
Thanks to the tips of SirNnoName without him I was still banging my head against a wall
I put a video on youtube to tell me if you see the movement is otherwise just give me some advice to improve the profile
1° Test
http://www.youtube.com/watch?v=-8MV0_8a ... e=youtu.be
2° Test I changed my profile in the converter
http://www.youtube.com/watch?v=1Z-327Dn1Cg
One question: I always have the memory driver enabled? not enough that I saved the profile?
Ps: I did do a few laps to my children every time they gave some shout .... means that it works :mrgreen:
Thanks in advance
regards Kevin
kevin123
Images: 132
Postby caiubbo84 » Mon 4. Jun 2012, 20:07
Hi Kevin,
Very nice your blue motion!
ciao!! ;)
caiubbo84
Images: 15
Postby motiondave » Mon 4. Jun 2012, 23:18
where did you find the x-sim manual?
Postby floriske » Tue 5. Jun 2012, 09:35
floriske
Images: 96
Return to Extractor questions
