Input info problem ?
Postby ericRacer » Mon 11. Feb 2013, 16:45
I try to use X-Sim³ and it is works well with a minor problem and i don't know why . I don't have any definition about the input force (in the input section from the X-Sim_converter) when i use force-extractor . I have to use the old version force-sender to be able to read the definition in the x-sim_converter (vertical,lateral,etc..). I did a registry cleaner but samething
What's the problem :?: :cry:
thanks
ericRacer
Images: 36
Re: Input info problem ?
Postby yokoyoko » Mon 11. Feb 2013, 16:57
Hi eric,
just for understanding. The extractor is running, you set this up correct and hit the play game button, game starts, meanwhile in the convertor the effects will not be "named" (vertical, lateral) and just "25 connect extractor for info"? Do you use extractor and converter on same pc?
Best regards
yoko
Postby ericRacer » Mon 11. Feb 2013, 17:26
Exactly ! :P
But i use the converter on an other PC .
thanks :P
ericRacer
Images: 36
Postby yokoyoko » Mon 11. Feb 2013, 17:43
Mhh - which version of x-sim do you use exactly? Which plugin/game you used? I had this one time in iracing - but it was never reproducable!
Postby ericRacer » Mon 11. Feb 2013, 17:49
x-sim 3.0.0.7b
i created a profile for GSC with rFactor plugin and like i said that works very well with force-sender :?
ericRacer
Images: 36
Postby yokoyoko » Mon 11. Feb 2013, 18:03
Would you mind try again with this release of x-sim³? http://www.x-sim.de/forum//dm_eds/download.php?id=2
GSC with rfactor plugin is the correct way. I use this alot atm without probs on v. 3.0.0.9
Postby ericRacer » Mon 11. Feb 2013, 18:08
ok, good, i am going to try it :P
I just try with iRacing with the official plugin and now i have this message in the input : disabled slot, plugin driver :cry:
ericRacer
Images: 36
Postby ericRacer » Mon 11. Feb 2013, 18:35
same problem ! but i thing there are something wrong in the extractor , when i push on the motion driver button > telemetry plugin > i should see a list of all my game's plugin (official ) but i have only for : falcon 4 , r.d.grid, Kartracing, rbr.
I am not able to check the box for enabling plugin developper !
i found something ! :? i am able to check the enable plugin developper, i had to check a plugin first , I check falcon 4 for fun and > Try send Data and i have the named force written in the converter, then..... now i know it's a plugin detection or installation in the extractor but i don't know why that works with force-sender :?:
ericRacer
Images: 36
Postby sirnoname » Mon 11. Feb 2013, 19:01
Maybe you get into problems because game plugins of 2.x are incompatible to 3.x?
Postby yokoyoko » Mon 11. Feb 2013, 19:39
For refernce what it should look like:
Return to Extractor questions
