Codemaster plugin crashed extractor
Postby kappacina » Thu 9. Jul 2020, 07:28
Hello everyone, I kindly ask if you can help me. Practically all plugins work except that of Codemasters. When I select it to match it to the game example dirt 2 dirt 3 etc I crash the extractor :-(. Only with that plugin, both that I do it automatically with the wizard whether I go to select it manually by going to the motion driver. I don't understand if some files have been lost or if the plugin is corrupt. Is that recoverable only or do I have to reinstall xsim? Thank you very much and have a good day.
Denis
kappacina
Re: Codemaster plugin crashed extractor
Postby sirnoname » Thu 9. Jul 2020, 18:07
You can try the registry cleaner. You can also try the codemaster updates here in the forum. In any case no crash is known with this plugin because it is a own executable running in the taskbar. I assume you have problems with starting the game in extractor instead of a plugin problem.
Return to Extractor questions
