Step 1 problem in motion driver setup
Postby buzzoom » Fri 21. Sep 2012, 22:30
In motion driver:
How to control if the step 1 (algorithm choose) is good ? Because I can see a diffrents values effect (21 to33) in ''X-sim converter''.
There are a link between algorithm choose and differents effect n°21 to 33 ? It seems to be a good algorithm choose if this effects moves ?
Bests regards
PS: I want realise a pneumatic simulator.
Buzzoom
(French ^^)
buzzoom
Re: Step 1 problem in motion driver setup
Postby buzzoom » Tue 25. Sep 2012, 21:06
I find the problem :-D ......
Westerday I test for the first time my pneumatic actuator with X-sim.
I have a good results for the moment.
In the next time I build the 2dof simulator with "wood".. (It's more simple for me ^^)
bye
buzzoom
Postby motiondave » Wed 26. Sep 2012, 00:35
ok then, glad you found a answer.
Postby turbo0321 » Sun 23. Aug 2015, 17:29
buzzoom wrote:Hi,
In motion driver:
Bests regards
Buzzoom
(French ^^)
ok
turbo0321
Return to Extractor questions
