SCN5 freezing (Extractor problem?)
Postby Fahim » Tue 11. Apr 2017, 20:21
Good evening guys.
SCN5 both actuators just stop working after a few laps. Have to restart the Motion extractor. Because if I try to re-'PLAY GAME' then it says "error with adding to own profile database" Then if I press "play game" again it says Application Error. Unkown exception (0x4000015) occurred in the application at location 0x0052431c. Click on OK to terminate the program. Basically I am having to close the extractor down after the scn5's hang.
I think the freezing of the actuators after a few laps is due to the Motion Extractor. Does this make sense?
Fahim
Re: SCN5 freezing (Extractor problem?)
Postby sirnoname » Wed 12. Apr 2017, 15:59
Yes, the error is strange and it may be a good idea to start from scratch. You can backup the profile.db and the x-sim registry with registry editor. then you can delete both and give it a new try. If not, restore the backup.
Return to Extractor questions
