How To Change iRacing Browser From IE to Chrome?  Topic is solved solved with post #20459
Postby hpiguy » Wed 16. Nov 2016, 08:50
I've tried manually editing the line where the extractor uses IE, and putting in the path on my machine to the Chrome executable, but no dice. Certain things on the iRacing site don't work properly in IE, is there any way I can change this to Chrome?
hpiguy
Re: How To Change iRacing Browser From IE to Chrome?
Postby spyderwash » Wed 16. Nov 2016, 12:04
I can run the same with IE you'll just get to the login page and then open it with eighth notes, or whatever you want and it works and I do
spyderwash
Postby hpiguy » Wed 16. Nov 2016, 22:02
spyderwash wrote:I can run the same with IE you'll just get to the login page and then open it with eighth notes, or whatever you want and it works and I do
I don't understand what you mean? What I'm saying, is that there are things on the iRacing website that simply are not working in internet explorer. But, it appears that when using the X Sim extractor it is locked to internet explorer.
hpiguy
Postby spyderwash » Wed 16. Nov 2016, 22:52
also it uses IE as the default for x sim then you can use the browser that you just do not want to log in to iRacing
spyderwash
Postby hpiguy » Thu 17. Nov 2016, 01:15
So if I understand you correctly, I can simply let the extractor pull up the iRacing page in IE, but don't log in. Then launch Chrome manually, and log into iRacing there and X Sim will still work as it should?
hpiguy
Re: How To Change iRacing Browser From IE to Chrome?  Topic is solved
Postby spyderwash » Thu 17. Nov 2016, 12:06
It this is what I do I can also launch iRacing sim and then x and everything works
spyderwash
Postby hpiguy » Thu 17. Nov 2016, 16:11
Ah, I see, thank you sir!
hpiguy
Return to Extractor questions
