Project Cars - Bass Shaker problem:  Topic is solved solved with post #20334
Postby Lynxt » Sun 23. Oct 2016, 19:03
Have 2 amps one is powering Buttkicker and one is powering AuraSound AST-2B-4 bass shaker..
Everything looks fine.Made the setup extractor and convertor seeing each other i followed ricmotechs bassshaker tutorial pdf..
The problem is when testing test minimum and test maximum frequencies are working fine..
But when its come to game ı'm starting game from convertor but parameters is not coming from game ..
Any idea? Please help me on this one thanks.
Lynxt
Re: Bass Shaker problem:
Postby Nima » Tue 25. Oct 2016, 15:13
What Game Do you Play
Nima
Postby Lynxt » Tue 25. Oct 2016, 16:55
I'm playing Project cars. Selecting second soundcard and adjustments about bass shaker plugin is looking ok because when i test it i'm feeling maximum and minimum frequencies.
I adjusted math section like guides but somehow i havent seen any movement in game.
Starting the pcars64.exe from extractor and pressing start at convertor. Looks like programs are not seeing each other,
Or maybe i dont know how to get parameters from game..
Only thing I want is rpm at the beginning if i could learn how to add it I'm planning to add details like gear shifting, speed etc..
I placed one shaker under pedal other buttkicker to the seat. Spent like five hours with x-sim really confused and need help
Lynxt
Re: Project Cars - Bass Shaker problem:
Postby Nima » Tue 25. Oct 2016, 19:18
Look in pcars under options /Optik / Hardware and set the Shared Memory on
Nima
Postby Nima » Tue 25. Oct 2016, 19:25
Than Look in Converter / Output Setup and Look if the Output on bassshaker Not Midi bassshaker
Nima
Postby Lynxt » Tue 25. Oct 2016, 20:55
I attached the view of output menu there isnt any choice for midi or normal shaker..
What do i have to do?
Lynxt
Re: Project Cars - Bass Shaker problem:  Topic is solved
Postby Nima » Tue 25. Oct 2016, 21:15
The Output is right.
Do you have set the Shared memory in pcars on? Without this Pcars Not send data.is this Not work read the pcars Train is a problem with the 64 bit version.or Start with the 32 bit version
Nima
Postby Lynxt » Tue 25. Oct 2016, 21:42
Really thanks i used a profile that i downloaded before for shaker setup it worked ill work on it to adjust vibrations for better reality ..
Lynxt
Return to Extractor questions
