What op is suported ?
Postby caysie » Wed 11. Mar 2015, 09:02
Sorry, posted this question in the FAQ section, so may be better answers in here ?
I would like to try out the extractor software, to deside if it is usefull for my purposes. BUT I can´t get it to run !?
With win XP and IE8, it is not possible to logg on, and the software crashes after a failed log on attempt.
Then it is impossible to get a logg on window, even if I reinstall and clear reg.
With win7, same hardware all works fine. So, no connectivity problems in my network.
The thing is :
-I can´t run win7 on the servers I intend to use for my project.
-I will happily buy a license key, but first I need the software to work with my hardware.
And because the Licence Key is locked to the computer hardware, wich I don´t desided exactly what to use -I can´t buy a licence ether !?
I´m STUCK, Please help !!
caysie
Re: What op is suported ?
Postby sirnoname » Thu 12. Mar 2015, 01:03
Hi, you can use any IE from 6 and up. Servers are not tested, they are not designed for games.
if you have login probs, you can first try this forum login with IE.
Postby caysie » Thu 12. Mar 2015, 16:23
Thans for your answer "sirnoname"
I can´t get it to work on any computer exept a small notebook with win7 starter.
on this computer I have a different username, wich I don´t remember, it was used only for downloading the software.
Then I created a new user and password to use "seriously", I have tried with both win7 and XP all with IE6 and up. No success :(
-Maybe my account is "banned" or "blocked" backause of this, both uses the same ip adress of course.
I can log in on this forum from all computers I have tested x-sim with, and all ports needed is opened in my firewall :?:
caysie
Postby sirnoname » Thu 12. Mar 2015, 19:06
Do you have special characters in your password?
Postby caysie » Thu 12. Mar 2015, 20:14
No, nothing, only normal characters.
One thing I see now is that sometimes the IE browser goes into "compatibility mode" to wiew the forum on my "problem" computers.
This is not normal ?
-Will check my router and try another one.
caysie
Postby caysie » Thu 12. Mar 2015, 23:15
Tested with other router, tested with other ADSL modem. And finaly tested on my work.
-No conection.
So many hours spent.... -I give up :|
caysie
Return to Extractor questions
