Registry cleaner
Registry cleaner
Postby Fahim » Thu 2. Jan 2014, 21:32
I uninstall/install twice and have tick on registry clean. But it doesn't.
It always remembers the details history. Even when I uninstall I delete the yellow x-sim folder from program files.
Also the registry cleaner runs, then kind of always locks up and stays at the bottom of the task bar.
windows 7 64 bit. help appreciated. Thanks.
Fahim
Re: Registry cleaner
Postby sirnoname » Thu 2. Jan 2014, 23:04
What is your problem and what is the details history?
Postby Fahim » Fri 3. Jan 2014, 00:42
Install x-sim 3: yes
Clean registry: yes
Registry starts to clean
registry program seems to work but icon (green x) always be's at the task bar (as if program hanged/locked up)
When open x-sim 3: all values and data from previous install are still there.
Fahim
Postby sirnoname » Fri 3. Jan 2014, 01:48
and if you use the registry editor to delete all X-Sim setup?
remove
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\X-Sim
or
HKEY_LOCAL_MACHINE\SOFTWARE\X-Sim
Postby Fahim » Fri 3. Jan 2014, 20:14
Thanks. I will try that.
Fahim
Return to Extractor questions
