Help on/off trigger
Help on/off trigger
Postby kevin123 » Mon 29. Jul 2013, 19:34
Hello guys
I have a problem I can not solve with the on/off switch trigger in practice I do not know if I'm wrong but something about versions older than x-sim was enough to set as in the picture below
and working motion on/off button # 1 of my g27
now I can not get it to work in any way .....
Because I would set presentation view when you start x-sim and now I have the second monitor to turn on and turn off the start and stop of x-sim with on / off trigger would be the best solution for me
thanks
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Re: Help on/off trigger
Postby sirnoname » Mon 29. Jul 2013, 21:55
Don't know what you mean. This option has not changed.
Normally you use the math setup and joystick input to set the result value to 0.
Postby kevin123 » Tue 30. Jul 2013, 18:50
Hello Sirnoname
Sorry
With the translations of google you never understand well .... I did not say that and changed something in x-sim I know that the setting and always something that I definitely mistaken or missing a setting.
What I mean is this: that in older versions it worked and I had done nothing more than that and tick the box highlighted in screeshot without doing anything else.
Now I can not figure out what to do .... you mean the button on the joystick of the g27 I have to set it to 0 in the game? can you please make a screenshot so I understand it better?
EDIT:Perhaps I have ... you say that?
Button 1 g27 when pressed button corresponds to 0 in the input setup and the value 0 and if I press the button 2 corresponds to 1 and for this it does not work?
RE EDIT:
Solved ;)
Thank you very much
kevin123
Images: 132
Postby Erwan960 » Wed 31. Jul 2013, 19:28
Could you explain what you made please ? :D
Erwan960
Postby kevin123 » Wed 31. Jul 2013, 22:11
Sure!
I missed that you had also set in the program settings tab enable autostart trigger in x-sim converter
kevin123
Images: 132
Postby Erwan960 » Thu 1. Aug 2013, 08:30
Thanks ! ;)
Erwan960
Postby Erwan960 » Fri 2. Aug 2013, 22:31
In "motion driver setup", I choose "enable/disable... joystick button 6".
In "program settings", i unchecked "enable autostart trigger in x-sim converter", checked "trigger on a changing effect" and chose "trigger on effect: 54".
It still don't work :(
I think I have something to add in "math setup" but I don't know what...
In "interface settings", when I press button 6, the "test one interface input pin" give me a "100% result" and "ingame joybutton 6" effect #54 in "input setup" stay at 0 (current value).
Erwan960
Postby Tombo » Fri 29. Nov 2013, 22:26
i'm planing to build a wireless buttonbox out of an old kyboard so is it possible to use this function wiith a keyboardbutton too?
Tombo
Images: 36
Return to Extractor questions
