extractor not starting  Topic is solved solved with post #78
Re: extractor not starting
Postby wptm » Wed 27. Feb 2013, 22:26
I have Windows Vista installed. I'm trying to start extractor.exe from the latest 3.0.0.9 version. It says:
Extractor.exe - Entry Point Not Found
The procedure entry point K32EnumProcessModules could not be located in the dynamic library KERNEL32.dll
Well, I did some google and found at http://www.geoffchappell.com/studies/windows/win32/kernel32/api/index.htm:
Function Applicable Versions Documentation Status
K32EnumProcessModules 6.1 and higher documented (PSAPI)
Version "6.1 and higher" means at http://www.geoffchappell.com/studies/windows/win32/kernel32/history/index.htm:
6.1 Windows 7, Windows Server 2008 R2
Does it mean that Windows Vista is not supported by X-Sim? Only Windows 7?
wptm
Images: 57
Postby sirnoname » Wed 27. Feb 2013, 22:30
The extractor need new directx of win7. The converter can be run on lower OS.
Been thanked: 128 times
Postby motiondave » Thu 28. Feb 2013, 01:06
not sure about later versions of x-sim, but 3006 and 3007 runs on XP 32 bit, stage one version as graphics driver only works with dx 11. but it works for the usual games and plugins.
Otherwise all versions of x-sim run on 7.
Postby sirnoname » Thu 28. Feb 2013, 01:39
Dave you are right, the parts that do not fit get disabled by itself. The extractor is running on XP BUT you need:
Internet explorer equal or above 7 and all service packs.
Microsoft says:
If PSAPI_VERSION is 2 or greater, this function is defined as K32EnumProcessModules in Psapi.h and exported in Kernel32.lib and Kernel32.dll. If PSAPI_VERSION is 1, this function is defined as EnumProcessModules in Psapi.h and exported in Psapi.lib and Psapi.dll as a wrapper that calls K32EnumProcessModules.
Programs that must run on earlier versions of Windows as well as Windows 7 and later versions should always call this function as QueryWorkingSet. To ensure correct resolution of symbols, add Psapi.lib to the TARGETLIBS macro and compile the program with -DPSAPI_VERSION=1. To use run-time dynamic linking, load Psapi.dll.
Maybe the VS2010 do not use old psapi and 3008 (where I switched to VS2010) and above are in conflict with this version.
Very nice found, I will check this on saturday.
Postby sirnoname » Sat 2. Mar 2013, 17:09
Ok, that was definitiv a VS2010 problem.
It is solved now and starting again on XP in 3.0.1.0
if someone needs this new executable because of vista -> PM me!
Postby RafBR » Sun 17. Mar 2013, 02:31
The 3.0.0.9 version is not working here.
After install I start the Extractor and than Windows prompt something like" The file Extractor.exe could not be found..." and after that the file is gone :shock:
Than I reinstall x-sim and the file is back there again, but after I try to execute it again same happens.
Is there a 3.0.1.0 version out?
RafBR
Images: 24
Postby prodigy » Sun 17. Mar 2013, 03:09
It happened to me too few days ago, I think Avast! deleted my extractor.exe file for some reason and I couldn't run it anymore, Converter was fine though. After reinstalling I've added X-Sim folder in Avast Exclusion list and didn't have anymore problems with extractor file disappearing.
Postby wptm » Fri 29. Mar 2013, 20:01
wptm wrote:I have Windows Vista installed. I'm trying to start extractor.exe from the latest 3.0.0.9 version. It says:
I can start the extractor under Windows Vista with version 3.0.1.4. Thanks Sirnoname!
wptm
Images: 57
Postby setonfire » Wed 10. Jul 2013, 04:33
Hi guys. Got a problem with extractor that is driving me crazy.
Times ago i installed the full package and everything was all right, since one day when i tried to open the file it says something like: "impossible to find the specified file", but doesn't say which file. I tried even cleaning all registries and manually deleting the added keys from windows register. Reinstalled everything and it worked just for one run, than once again the same problem. I even set my antivirus to handle the exception of extractor.exe and even tried to disable it at all but the situation doesn't change. Any idea on what could be? I'm running under windows 7. Thanks in advance to all for any suggestion.
setonfire
Postby sirnoname » Wed 10. Jul 2013, 08:56
This is the notification that your .db file with game location informations is corrupt. If you press yes it will not ask again. This happens if you use antivirus and cracked games. The game executables get deleted by the antivirus and the database do not find the games.
Return to Extractor questions
