Login problem.  Topic is solved solved with post #24739
Re: Login problem.
Postby bugcrash » Sun 7. Feb 2021, 20:35
thanks sn - sorry I am not a programmer so I am not very good with debugging but shouldn't the SCN5 show up on the right side of the converter program under: All found interface plugins?? Please see attached pic. I am going to re-install Windows at this point as my old restore point 12/2020 is no longer available.
bugcrash
Re: Login problem.
Postby sirnoname » Mon 8. Feb 2021, 01:09
No need. You can also use the old converter with new extractor.
The debug option is described here: viewtopic.php?p=256#p256
HotkeyLocalMachine/Software/X-Sim/Force-Profiler2/Interface-Plugins/SCN5Serial
No need for a programmer.
Re: Login problem.
Postby bugcrash » Sun 21. Feb 2021, 23:08
sn - I installed an image of windows (Windows 1809) from 2019... I played a round of iRacing and the motion worked perfectly. I have paused Windows updates so I don't get 20H2. I updated my video drivers for RTX3070, took another image. I started Extractor / Converter all worked. I installed X-Sim_Setup_3.0.3.1_aluminum_13012021... I was going to follow you instructions... I don't have interface key in registry to set debug mode (see screen shot) Thanks
Registry After 3.0.3.1 update.PNG (7.3 KiB) Viewed 19275 times
bugcrash
Re: Login problem.
Postby sirnoname » Sun 21. Feb 2021, 23:15
Then add it.
Re: Login problem.
Postby bugcrash » Sun 21. Feb 2021, 23:33
I re-imaged back to earlier version from today... I am going to export current registry as seen in screen shot *.. This is with 3.0.2.9
Registry with 3.0.2.9.PNG (8.83 KiB) Viewed 19274 times
bugcrash
Re: Login problem.
Postby sirnoname » Mon 22. Feb 2021, 00:00
Did you read the SCN5 thread step by step instruction for debug mode?
Re: Login problem.
Postby bugcrash » Mon 22. Feb 2021, 00:23
I have enabled debug in registry, I am going to follow step by step
bugcrash
Return to Extractor questions
