extractor not starting  Topic is solved solved with post #78
Re: extractor not starting
Postby Riton » Sat 12. May 2012, 11:26
I respect the work on X-SIM,
I understand that this is important work and I know this is a free software that builds on the work during free time.
I would like if possible more communication:
Ex: I work on this problem, it is identified.
or ex:
I need more information ...
I want you to do testing ....
it's to help, I remain in the queue without information, so I could help and do a lot of testing to help find the problem.
thanks
Riton
Images: 70
Been thanked: 16 times
Postby motiondave » Sat 12. May 2012, 11:55
Riton wrote:I respect the work on X-SIM,
or ex:
thanks
did you use the registry cleaner part of x-sim? When you install a new version, you need to go to the reg cleaner and clear ALL settings. Yes it means you have to re-enter motor USO commands and all that (unless you have set up a save file), but this may help crashes. I know it has with me.
Postby Riton » Sat 12. May 2012, 13:04
yes i use registry cleaner, I uninstalled and installed several times
At the first installation it works well, if i close and start again i see the error and Extractor was closed by win dows error message.
I uninstalled again and delete the C/PROGRAMM/XSIM and try again but i have the same problem .
I feel that this is when it shows "* cloud" that is wrong.
just for this function, crash
I also noticed that I did not need to open "extractor" in the program administrator,
before it was necessary.
open in administeur or not has no effect.
on my 2nd PC, it is necessary
it's two computers "Seven 64"
Riton
Images: 70
Postby tronicgr » Sun 13. May 2012, 06:20
Yes, you should remove all previous versions and clean the registry. You cannot have both versions together.
There is one trick that can be done though... I made a thinstall portable version of profiler2 just to be able to use some old plugins until they integrated into the x-sim3. ;)
Postby Riton » Sun 13. May 2012, 11:10
Yes,
I uninstalled XSIM2, past RegCleaner , and installed XSIM 3.
it works once and after a reboot, it does not work.
I already do that 2 times.
Now to use my simulator, I installed XSIM2 another folder, I created a folder "X-Sim2" in C / program
and it works perfectly well with XSIM2.( i have XSIM3 too )
but if you want i can do a new installation...
I will start a new installation "clean"
RegCleaner, complete uninstall, delete folder XSIM and new installation.
I give you the information again later
Riton
Images: 70
Postby motiondave » Sun 13. May 2012, 11:50
Riton wrote:Yes,
Are you running any anti virus software?
Postby Riton » Sun 13. May 2012, 12:01
Riton
Images: 70
Postby motiondave » Mon 14. May 2012, 10:50
I had a thought, if you really want to keep x-sim 2089, get another hdd, install your favourite OS on it, then use f12 at boot up and select the hdd with 2089 on it. Yes you will have to reinstall all your games on it, but you have the option of still using the sim if you are not happy with x-sim3.
Then you can go back to the x-sim 3 installed on the current hdd and sort it out.
But really...for goodness sake ...give sirnoname a chance to sort this out. Everyone wants everything to work perfectly first time, and when something does go amiss, there are some people the first to carry on about it. X-sim 3 is VERY good and shows great potential. Give it a chance to be sorted. Help with beta testing so Sirnoname can fix issues. Join the rest of us in helping this develop, and remember....we would NEVER have our own home brewed simulators if it were not for this software.
Postby Riton » Mon 14. May 2012, 22:52
yes!
I'm still working on "SIM3"! of course it is important that there is beta testers!
I have not had time to reinstall everything, but I will do a new clean install of XSIM3.
and test again.
Riton
Images: 70
Postby caiubbo84 » Mon 17. Dec 2012, 20:36
Hi to all!!
today i had the same problem! extractor doesn't work! i'm not sure but this problem is caused from ccleaner after cleen regestry extractor stop work, and start this oddesy! i reinstatted 10 times xsim but not work! HELP!! :?
caiubbo84
Images: 15
Return to Extractor questions
