Problem game NoLimits  Topic is solved solved with post #471
Re: Problem game NoLimits
Postby kevin123 » Sat 9. Jun 2012, 10:12
caiubbo84 wrote:Hi Kevin,
Very nice your blue motion!
ciao!! ;)
thanks ;)
motiondave wrote:where did you find the x-sim manual?
Hello David
The manual and that has reported floriske qnche and I read what you gave me and I translated in my language both have helped me through ;)
One question ..... I can not see my project and even if I go to the others manage projects wiper motor does not see it only if I click on My projects I see
Regards kevin
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby Riton » Thu 20. Sep 2012, 20:59
I have the 1.8 NoLimitrolercoaster version. (Official version purchased.)
I tried to run the simulator, but I have no motion and no values.
What should I do?
I essaé to what is stated above, but it does not work ...
Thank you for your help
Riton
Images: 70
Been thanked: 16 times
Postby sirnoname » Fri 28. Sep 2012, 11:49
Can you give more details.
Did you setup the memory driver? How?
Postby museumsteve » Sun 28. Apr 2013, 02:09
I still dont understand why No Limits is such a problem for me :(
I have done everything I can see.
I have offsets profile from online database...althoughI cannot see one for 1.8 so used 1.7
Now when I started the game from Extractor, my seat makes one movement like it is ready to start but nothing..and values dont change.
The values which show in Converter are all -2147483648
I have put the rollercoaster plugin in NoLimits plugins folder. Should an Outsim popup appear at all :s
museumsteve
Postby caiubbo84 » Sun 28. Apr 2013, 06:13
Have you windows 8?
caiubbo84
Images: 15
Postby museumsteve » Sun 28. Apr 2013, 11:03
It's Windows 7
museumsteve
Postby caiubbo84 » Sun 28. Apr 2013, 11:09
museumsteve wrote:It's Windows 7
Ok perfect. The problem is that you need to research the values with cheat engine. The pointer values are assigned from the OS so different versions of Windows or of game can be different. ;)
Regards
caiubbo84
Images: 15
Postby museumsteve » Sun 28. Apr 2013, 11:28
Okay, i didnt realise that :s
Thanks for the reply ;)
museumsteve
Postby sirnoname » Sun 28. Apr 2013, 13:12
That is new to me, possible but new. I check the values.
Postby caiubbo84 » Sun 28. Apr 2013, 13:30
I had the same problem after reinstall windows and on windows 8 the pointer is dynamic every time! There can be that microsoft implemented a new anti-cheat sistem! I think!
This what i think becouse museumsteve in dma have strange values!
In this days i neeted to format and reinstall windows several times and all my pointer adresses was changed!
caiubbo84
Images: 15
Return to Extractor questions
