Login problem.  Topic is solved solved with post #24739
Re: Login problem.
Postby sirnoname » Thu 14. Jan 2021, 19:18
Bergison & masibabato -> you have pm!
Re: Login problem.
Postby spyderwash » Thu 14. Jan 2021, 22:29
same problem my login is blocked after update
spyderwash
Re: Login problem.
Postby Bergison » Thu 14. Jan 2021, 22:35
I just got to test an updated version of x-sim from sirnoname and with this update, the login (and thus everything else) is working again.
Sirnoname needs more testers, so please chime in guys, so we can have a working release version soon!
Bergison
Images: 20
Been thanked: 9 times
Re: Login problem.
Postby sirnoname » Thu 14. Jan 2021, 22:51
The question would be - which update and can it be rolled back for a check?
Re: Login problem.
Postby spyderwash » Thu 14. Jan 2021, 22:53
spyderwash
Re: Login problem.
Postby spyderwash » Thu 14. Jan 2021, 23:56
if you want I can be a tester
spyderwash
Re: Login problem.
Postby masibabato » Fri 15. Jan 2021, 01:15
Sirnoname.... YEP... your new beta version is working well. No problems so far... Thanks.
masibabato
Re: Login problem.
Postby chafer » Fri 15. Jan 2021, 07:49
Bergison wrote:I just got to test an updated version of x-sim from sirnoname and with this update, the login (and thus everything else) is working again.
Sirnoname, I am ready to test the beta.
chafer
Re: Login problem.
Postby BlancatM » Fri 15. Jan 2021, 11:19
Where si the new beta versión?...is 3.0.3.0? Or newer...
BlancatM
Re: Login problem.
Postby spyderwash » Fri 15. Jan 2021, 12:50
I did some tests, removed the latest windows updates and reinstalled, it took a long time or the updates are heavy but then everything started working again with the old version
spyderwash
Return to Extractor questions
