scn5
scn5
Postby sasgb » Sun 2. Jun 2013, 18:57
Hello
x-sim 3.0.1.4 and 3.0.1.5 do not recognize my scn5?
the 3.0.0.7 release no probleme
thank you not to answer
sasgb
Re: scn5
Postby sirnoname » Sun 2. Jun 2013, 18:59
Disable all other plugins and USO entries.
It is the XPID Plugin which has to get fixed ;)
Remove this check.
Re: scn5
Postby sasgb » Mon 3. Jun 2013, 17:14
sirnoname wrote:Disable all other plugins and USO entries.
Remove this check.
thank you for your answer is OK :D
sasgb
