Dimension Engineering Kagaroo / Sabertooth Plugin
Postby telfel » Fri 26. Apr 2013, 18:53
Hi Sir
Would you please consider creating a plugin for the new Kangaroo x2 and Sabertooth Driver using packeritised serial interface,
attachment of manual etc in this thread
http://www.x-sim.de/forum/viewtopic.php?f=43&t=867#p7441
I have 24 volt 27 amp run, 590 watt motor wormgear units, I intend to build a 2 dof to start, then I hope to build a 6 dof, using the 2 x 60 sabertooth.
Have tried the cheap china drivers and fried a few in testing
The kangaroo x2 plus sabertooth 2 x 25 could offer a 24 volt alternative to the JRK, Dimesion Eng have dealers across most of the world, or their international shipping from the US is cheap. So may suit the X-Sim community.
thanks Terry
telfel
Images: 54
Been thanked: 9 times
Re: Dimension Engineering Kagaroo / Sabertooth Plugin
Postby motiondave » Sat 27. Apr 2013, 05:36
looks interesting
Postby ferslash » Mon 29. Apr 2013, 21:44
just playing the role of devil's lawyer... i got a comment
this cards + saberthooth are cheaper than jrks, that is grate
but they are more expensive than arduino+2 h bridges...
are this cards (kangaroo+sabertooth) superior than the arduinos???
-- just qurious--
best regards guys and thanks for researching for the community
fer
ferslash
Postby ferslash » Mon 29. Apr 2013, 21:52
*** sorry i re-read the topic, i guess the thing is that sabertooth can run bigger motors, currents and volts...
as i said... thanks for doing this for the community
fer
ferslash
