Question to SirNoName
Postby RafBR » Fri 25. May 2012, 22:33
Hi Sirnoname!
I wish you could make one executable tool or anything that could help me to set the core 0 (zero) to back to all programs after I exit the converter.
What I mean is that I always have to restart my system or I have to CTRL alt del and change it manually to use 3ds max or other heavy core demanding software.
I think the most obvious way would be it automaticaly reset this when exiting the converter ;)
regards!
RafBR
Images: 24
Re: Question to SirNoName
Postby motiondave » Fri 1. Jun 2012, 15:13
I know this question is not aimed at me, but what other cpu demanding software are you trying to use? I know 3ds max would be thirsty for power.
Also, its a weird one , do you auto isolate x-sim to first available core?
Are you trying to run your 3ds software at the same time as x-sim or in the background?
Is your cpu even powerful enough?
I know I have to stop programs from running to get x-sim to run smooth, including stopping messenger. Although the Morton Antivirus doesn't affect it.
Postby RafBR » Fri 1. Jun 2012, 18:11
When I use x-sim I want it to be like it is. But when I am not I want all my cpu cores working for me. As I said I can make it by ctrl+alt+del and setting afinity but it is a little bit annoying to do it all the time I restart 3ds max for instance.
The only way to avoid it is restarting the whole system (after the use of x-sim).
I work with i7920 that is, 8 threads but it is in fact only 4 cores. The core 0 used for x-sim is 1/4 of its raw power. Trust me, I know what I am talking about! I work with this system for almost 2 years and with 3ds since 18 years ago (3ds R4 DOS).
If Sirnoname could make x-sim change this core back to whole system use after one game session would be very nice. If not, I can live with it! :)
regards!
RafBR
Images: 24
Postby motiondave » Sat 2. Jun 2012, 00:20
Sorry, I didnt mean to question or doubt your choice of cpu, just asking.
At least you understand the value of a decent cpu, a lot of people miss that bit.
Postby sirnoname » Sat 2. Jun 2012, 01:45
Postby RafBR » Sat 2. Jun 2012, 02:04
sirnoname wrote:Seesaw Pro:
http://www.mlin.net/SMPSeesaw.shtml
Humm, nice! This may solve my issue. I will give it a try.
Thanks!
RafBR
Images: 24
Postby RafBR » Sat 2. Jun 2012, 02:06
motiondave wrote:Sorry, I didnt mean to question or doubt your choice of cpu, just asking.
No problem, I know you just want to help :D
regards!
RafBR
Images: 24
Postby sirnoname » Sat 2. Jun 2012, 02:28
And if not: you know where the feature request button is ...
Postby RafBR » Sat 2. Jun 2012, 13:02
sirnoname wrote:And if not: you know where the feature request button is ...
Yeah I installed that software and my first thought is that it is not much more practical than ctrl+alt+del so I will use the request :D
RafBR
Images: 24
