How to adjust -> BassShaker ?
Postby ericRacer » Mon 4. Mar 2013, 20:14
  For some time I try to adjust this plugin and I do not know how? :(
Example: I choose 10hz and 100hz minimum as maximum, then I selected in G-Force RPM gives me 0min - 1000 max (example) and if I choose 50% in the intensity, it means that I have a sound 10hz-45Hz (50%). Now, what if I want to add an additional force which will operate at 60hz - 75hz? :?
thank you for your help! :P
ericRacer
Images: 36
Re: How to adjust -> BassShaker ?
Postby ericRacer » Wed 6. Mar 2013, 02:17
:cry: :shock:
ericRacer
Images: 36
