problen with velleman sabertooth
Postby ESKUDERO88 » Thu 10. May 2012, 09:42
hola gente desde hace ya dos semanas vengo configurando el profiler para sabertooth y velleman vm 110 y no tengo manera de conseguir que funcione correctamente si alguien pudiera explicar su correcta configuracion o subir un archivo base para partir de ahi lo agradeceria enormemente SALUDOS
hello people from two weeks ago I came to configuring the profiler and Lcd sabertooth vm 110 and I have no way of getting it to work properly if someone could explain the correct settings or upload a file from there base would appreciate it greatly GREETINGS
ESKUDERO88
Re: problen with velleman sabertooth
Postby kevin123 » Wed 20. Jun 2012, 17:19
Hello ESKUDERO88
Take a look at projects and find blue racing sim K8055 + Sabertooth where I put my configuration of x-sim test to see if it is helpful
regards kevin
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
