Converter crash
Converter crash
Postby deniscina78 » Thu 15. Nov 2012, 14:38
Hello everyone! I kindly ask your help.my simulator has a piston front (Y) and one lateral (X).
I downloaded the latest version of x-sim(3.0.0.6). When I use the official plugin (example Dirt 2) and send data to converter everything ok, When I start the race x-sim crash! Interface was not loaded :-(. If I launch only Y axes and I play the game with plugins all ok! If I only launch X axes or or x and y axes x-sim crash.What 's the problem?Thank's a lot!
Sorry my English;-)
Denis
deniscina78
Re: Converter crash
Postby sirnoname » Thu 15. Nov 2012, 17:28
There are some parts missing in your mail:
1. which interfaces or actuators
2. will it work if you only disable the output but the axis calculation (math setup) is running
3. install 3.0.0.7
4. pictures of crash (cam or screenshot)
5. Profile file of converter that I can load
Re: Converter crash
Postby prodigy » Thu 15. Nov 2012, 23:39
I've had problems with interface not loaded and converter crashing and they were gone when I unchecked option "Auto isolate X-sim converter process on first CPU" from Program settings.
Re: Converter crash
Postby deniscina78 » Fri 28. Dec 2012, 13:41
Hi to everybody and excuse my English.I have a problem with the converter.I use a card k8055 + vm129 on hydraulic system. The position of the pistons as like rock'n ride. 2 lan pc with win 7 and x-sim vers. 3.0.0.7.
Unfortunately when I begin to play, sometimes after 2 minutes, sometimes after 10 seconds, appears me this writing and the converter crash: "interface dll was not loaded" For the first 2 days everything work perfectly, good plugin and I'm very happy, then in a moment I've have this problem.
I change the poti, software, hydraulic oil, bar pression, but nothing. Try to lunch x-sim in local running mode but nothing. I've another k8055, has tried to replace her but nothing, decrease and increase value plugin
I also try with only one effect for axes, 25 and 26, but nothing, after 1 or 2 minutes...Interface dll was not loaded.Try hardware rescan, and then press start and work for other 1 or 2 minutes and then some problem what's happen?
Please see the video below and if possible help me. Thanks so much!!
Denis
https://www.youtube.com/watch?v=ro1EP2C8eIYdeniscina78
Has thanked: 0 time
Been thanked: 0 time
Private messageE-mail deniscina78
deniscina78
Re: Converter crash
Postby sirnoname » Fri 28. Dec 2012, 13:58
This means you had a USB disconnect. You have to insure the mass connections is save from spikes and you use a save USB connection (1,5m cable etc.).
Also your output speed (artificial synaptrix break in program setup) cannot be fast. Try 33ms.
