MDL BDC24 Motor Controller
Postby telfel » Mon 9. Apr 2012, 17:55
Hi
can this be made to work with X sim3
specs looks good 12-24volt 40amps run 60amp for 2 secs
internal heatsink/fan for cooling,
available in the uk for £80.00
please see attached user guide for serial command structure
regards Terry
SW-RDK-BDC24-UG-8555.pdf
(273.43 KiB) Downloaded 956 times
telfel
Images: 54
Been thanked: 9 times
Re: MDL BDC24 Motor Controller
Postby motiondave » Tue 10. Apr 2012, 10:02
Maybe, looks possible, depends if someone has the cash to splash to test.
Postby sirnoname » Tue 10. Apr 2012, 14:04
A plugin is always needed. USO is only a workaround for development.
If you provide such a setup we can do it. (Interface plus small sample engine and encoder)
