Plugin Liveforspeed
Plugin Liveforspeed
Postby zapata » Sun 8. Apr 2018, 21:42
Good, I'm trying to adjust dirt4 with the liveforspeed plugin, I add the vertical effect force, automatic frame max value, until there is all perfect I receive the telemetry and I see the math setup graphic, but when removing the automatic adjustment and testing the movement the cockpit does not does nothing, however with dirt2 and the codemaster plugin works of luxury, any solution?
zapata
