No input from Assetto Corsa  Topic is solved solved with post #19763
Postby Tummie » Wed 27. Jul 2016, 13:36
Dear X-sim community, I use x-sim for project cars and it works perfectly fine. Assetto Corsa also used to work very well with x-sim, but somehow it's giving me the following problem since yesterday:
I use the latest plugin (October 2015) and keep in mind it did work until yesterday.
- run extractor as admin
- run converter as admin
- select the AC-profile (made 10 new ones trying to fix it, deleted the game from left, registry clean, logged on again, autowizard, nothing helped.) Anyway...
- the game boot perfectly fine and I get confirmation "Game detected" (play game button stays grey/black)
- press START in converter and it says it's working (button is red)
The problem is, the converter (or maybe the extractor, idk) is not getting any data. The math setup tab in the converter show the blue "datagraph" and it's moving but it just stays flat.
Please advice for it's wrecking my mind. One other thing; I have experienced this problem one time before, but after starting project cars, which always works, and starting AC again, it was fixed. Unfortunately this time that fix doesn't work.
I tried rebooting 30 times, did the complete sirnoname plugin installation tutorial, was already updated to AC version 1.7 last week, so it did work after that.
Tummie
Re: No input from Assetto Corsa
Postby sirnoname » Wed 27. Jul 2016, 20:43
Do screenshots of converter, check if joysticks are working, check the assetto post here in the forum.
Postby Tummie » Wed 27. Jul 2016, 21:21
Hi Sirnoname, joystick (steeringwheel) is recognized and in the input tab it shows the turning of the wheel and gas brake and all other buttons. In both screenshots I pressed the gaspedal around 80% and turned the wheel slightly to the left. Its just a buttkicker, but it means the world to me.
Tummie
Postby sirnoname » Wed 27. Jul 2016, 21:32
Did you follow the post here in the forum for the setup of assetto?
Postby Tummie » Wed 27. Jul 2016, 22:05
Yes, I followed your (and the rest of the Assetto corsa) post: viewtopic.php?f=30&t=773&start=100#p13167
Exactly like that but with this plugin : viewtopic.php?f=30&t=773&start=160#p17881
And it used to work. I just carefully tried all the steps again, but the problem stays the same.
Here you can see the difference between Pcars (with data) and AC (all zeros, except for the joystick which does gets recognized):
I also did a "Verify integrity of game cache" in Steam, but that didn't help either..
I will try a full reinstall of Assetto Corsa now and let you know if it worked.
Tummie
Re: No input from Assetto Corsa  Topic is solved
Postby spyderwash » Wed 27. Jul 2016, 23:08
manually enter the game and not with research and work
spyderwash
Postby Tummie » Wed 27. Jul 2016, 23:57
The full reinstall didn't work.
@Spyderwash, you should be given a medal. I did autosearch, but with manual setup. Bit of fiddling with the settings as all the screens were new to me, but now it works again. Thank you and Sirnoname for helping me out!
Tummie
Postby spyderwash » Thu 28. Jul 2016, 10:00
well I'm glad it works :D
spyderwash
