axis one and axis two-control
Postby lolek » Sat 23. Jul 2016, 08:37
Hello wszystkich.Mam small problem.I have a simulator with two engines, one is GForce and two to the brake and gas. and the question of whether I can get ready files (one and two axis) in the converter to control the simulator with a different possible effect?
lolek
Re: axis one and axis two-control
Postby sirnoname » Sat 23. Jul 2016, 09:04
Every simulator is different and you MUST follow the tutorials.
Postby lolek » Sat 23. Jul 2016, 11:28
yes I know . but before I had a simulator 2 dof and worked and now remade on 1 engine g-force and two brake and accel. . engine responsible for the g-force works a little and not two, but sometimes moves do not know when.
lolek
Postby sirnoname » Sat 23. Jul 2016, 14:05
You can describe step by step what you did, and I can tell you where your problem is. Screenshots do help.
